Help!!!! - JeepForum.com
post #1 of 2 Old 07-30-2001, 02:05 AM Thread Starter
I-4
I-4's Avatar
Help!!!!
am having problems w/a vaccumm leak on a 95 4 popper
i've replaced all the rubber fittings at the end of the plastic.but when the brakes are pumped it goes from around 650-700rpm to around 1000 rpm.the only 2 things not replaced are the fittings on the front axle(holding out for the cable kit )and the vaccumm boost on the brakes.what is causing this problem?HELP!!!!
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #2 of 2 Old 08-05-2001, 04:35 PM Thread Starter
I-4
I-4's Avatar
i found my problem:stupid vacuum boost for brake was going south! should be fixed soon!
95 yj...
I-4 is offline
