HEI INSTALL 84cj7 - JeepForum.com
post #1 of 3 Old 05-03-2013, 09:58 PM Thread Starter
NickP84CJ7
HEI INSTALL 84cj7
Hey everyone hopeing someone can help me out.
I just recently bought a 1984 Jeep CJ7 4.2 258 inline 6
as a project car and ive done alot of repairs already and am ready to
install this HEI Distributor I just bought and i need a little advice as what to do. I just replaced the carburator, unfortuneatly they gave me one with electronic feedback which i know you dont use with an HEI.
Carb i bought http://www.autozone.com/autozone/par...4_104859_1879__ and this HEI http://www.summitracing.com/parts/su...jeep/model/cj7. from the carb i have a fuel line going to the top of the engine block and one going to the vacuum advance. i hope someone can help explain how to put the distributor on properly and alos the connections i need to make to the carb. also carb is not recieving fuel since i put the new one on cause i havent been able to start it cause of the ignition problem, would this be because the jeep isnt on and fuel pump hasnt activated and if so would i just use starter fluid to get it going?
Thank you to whomever has time to respond and help it much appreciated.
Nick
NickP84CJ7 is offline
post #2 of 3 Old 05-03-2013, 11:18 PM
1986cj
Wellcome Nick, Your first post I see. Post this in the CJ forum and you will get a lot of info as a lot of the CJ guys run a HEI.
1986cj is offline
post #3 of 3 Old 05-04-2013, 01:25 AM Thread Starter
NickP84CJ7
Thank you!
carb , cj7 , distributor , help needed , project jeep
