Heep won't start unless pedal to floor, non-existent idle, must feather the go-pedal - JeepForum.com
post #1 of 2 Old 08-26-2005, 11:23 AM Thread Starter
Blthomas
Blthomas's Avatar
1979 CJ7
It's a 79CJ7 with the 258. When running it runs fairly smooth. Getting started, especially after sitting overnight or for multiple nights is a little trickey. I can't drive it right now due to some issue's I'm addressing this weekend.
BUT, if I can get a heads up on where or what to start with I want to try and diddle her a little on Sunday. Note, it will start up somewhat easier if I've run it a little and shut her down.
Not sure of carb, I ASSume it's a carter, haven't had the air cleaner off to look yet and only had the Jeep itself for about 3 weeks.
Many thanks for any thoughts or input you give,
Blair
Blthomas is offline
post #2 of 2 Old 08-26-2005, 03:22 PM
MASTERJEEPER
A few suggestionsthese are just simple thing to check)
Check the choke. They get stuck shut on the older CJ's.
check the butterfly valve for proper "flappage" If it doesn't move freely, it may be time a minor carb rebuild.
Make sure that your idle adjustment screw hasn't backed out.
MASTERJEEPER is offline
clutch problems soft pedal bustemduck Engines & Drivetrain 1 08-28-2012 09:12 AM
LJ dead pedal/ foot rest pics popeyesides Fabrication Shop 8 08-25-2009 05:53 PM
My dead pedal/ foot rest!!!! popeyesides Cheap Tricks & Fixes 1 08-21-2009 09:22 PM
Clutch pedal pressure with Ford T-18 and 302 lars915 Engines & Drivetrain 0 02-13-2009 11:19 AM
No clutch pedal mek Engines & Drivetrain 3 11-23-2008 10:15 PM
