heeeeelp. TJ won't start on first attempt - JeepForum.com
post #1 of 8 Old 07-02-2013, 09:47 PM Thread Starter
itsaliciayoo
I have a 2001 tj jeep wrangler sport. I've had it for almost two years now and just with in the last week it won't start the first time. It starts the second time just fine except the occasional 1out of 20 it takes 3 or 4. It doesnt matter if its hot or cold out, but if its been sitting more than 2hours it will not start the first time. It will just keep cranking. Had the battery checked out and it tested 100% no engine lights or anything. Took it to the mechanics and they couldn't find anything wrong with it.
itsaliciayoo is offline
post #2 of 8 Old 07-02-2013, 10:07 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its probably the anti drainback valve.
Its with the fuel pump assembly in the tank.
Bad anti drain back valve allows the fuel line to empty. Then it takes longer for fuel to hit the rail and you crank a little longer.
Your first crank primes the fuel line and gets fuel to the rail. Then it fires right up on your second crank because fuel is there.
Wheelin98TJ is offline
post #3 of 8 Old 07-02-2013, 10:28 PM Thread Starter
itsaliciayoo
Does this require the whole fuel pump to be replaced or can I just replace the valve. Also if there was something wrong with the fuel pump wouldn't it cause the engine light to go off.? Cause there is no light.
post #4 of 8 Old 07-02-2013, 10:36 PM
Agent620
Just the check valve.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Thanks to Anticanman who gave me a membership!
Chris Hansen is reading this thread.
If you've ever been in that traffic, you would have ground down the steering wheel with a death grip too. "Just ****ing GOOOOOO!!!!"
I pitty anyone who tries to reach into that netting unaware.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #5 of 8 Old 07-02-2013, 10:47 PM Thread Starter
itsaliciayoo
Originally Posted by Agent620 View Post
Is that the sane as the anti drainback valve.?
post #6 of 8 Old 07-02-2013, 10:49 PM
Agent620
Yes, anti drain back valve, check valve, fuel filter. Same thing. I just replaced mine last week and no more hard start. Took me about an hour to replace it.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #7 of 8 Old 07-02-2013, 11:40 PM Thread Starter
itsaliciayoo
Thhhhank you so much guys.!
post #8 of 8 Old 07-03-2013, 09:10 AM
Agent620
Happy to help, be sure to fill out your profile also.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
