header bolts? - JeepForum.com
post #1 of 4 Old 03-11-2002, 07:49 PM Thread Starter
CJ Lover
header bolts?
The bolts in my headers come loose all the time. It seems like Im always tightinen em. Any suggestions????
85 CJ-7. 79 vette 350 conversion. 4.56 gears. Lockers. 4" Explorer Pro Comp suspension, 3" body lift. 38" Super Swamper TSL's. Looking to go SOA and take off the body lift.
CJ Lover is offline
post #2 of 4 Old 03-12-2002, 08:32 AM
HabaneroEater
This may seem like a PITA, but it is well worth the headache. First off let me say that I have tried all the trick header bolts known to man and they all work for awhile and then it's back to the same old problems. For this old drag racers trick you can use any type header bolt, but I used the type with the allen wrench type head on them. You will need the following....
Header bolts and a couple nuts
Safety wire
Drill and drill bit
Vise
Take your header bolt and screw a couple nuts on the threads. Place it in a vise with the head above the vise jaw. Drill a small hole all the way through the head of the bolt. Repeat for every header bolt. Clean up any burrs on the header bolt. Install the header bolts and torque them down to spec. Run the engine and get things nice and hot. Let it cool and retorque the header bolts. Thread the safety wire through the holes in the header bolts. Three times is about maximum depending on how big the head of the bolt is. Connect them all or two at a time. How you do this is purely up to you, there is no right or wrong way. When the header bolts try to back out they will not be able to as the safety wire and the other header bolts that it's ran through will prevent it. If you run the safety wire over the top of a header tube it will burn the wire or it may become corroded enough that it gives out and breaks. This takes a long time. Just remove it and re-thread the safety wire after checking the torque on the header bolts. I did this on my '78 Z28 3 years ago and it is still holding. I do not drive it every day however.
Fear....Tastes just like chicken!
HabaneroEater is offline
post #3 of 4 Old 03-12-2002, 05:19 PM Thread Starter
CJ Lover
Sounds like a good idea. I woulda never thought of that. Thanks a lot
CJ Lover is offline
post #4 of 4 Old 03-12-2002, 06:16 PM
Bulletproofcj7
Habie has a great suggestion, ive been planning on doing that mod myself, for now ive used copper gaskets and extra thick lock washers,chase(clean) the threads in the head and lock tite the bolts also.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
How to tell, 4.2 vs 4.0 header UTChavok Engines & Drivetrain 1 02-07-2009 09:46 AM
What header? Samdweezel05 Engines & Drivetrain 1 01-13-2008 06:13 PM
Header mizzouxj Street Jeep Forum 20 12-18-2006 04:18 AM
Which 4.0 Header? Iwantawrangler Engines & Drivetrain 2 08-28-2006 06:23 PM
Header Marcelo32109 Engines & Drivetrain 5 05-29-2006 08:11 AM
