Head gasket replacement DONE project complete, photos/video - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Head gasket replacement DONE project complete, photos/video
Save on Selected Dynomax Exhaust Systems!Rough Country Lift Kits and Parts!All Bilstein shocks & struts - Lowest Prices Ever and
Unread 10-14-2014, 10:19 PM   #1
IROCZman15
Just wanted to write a brief post about my cylinder head replacement project. (1995 Jeep 2.5 Auto-transmission 152,000 miles )
for details on how it blew please view my other topic at:
http://www.jeepforum.com/forum/f12/1...start-2463201/
Ok, so basically once I had a few free hours in September I was able to tear into this issue. My assumptions were correct in that the head gasket was spent and the head was warped. I pulled the head off, saw this nasty "ballooning" of parts of the head gasket too. the head and the block were NOT cracked. I took the head to a local machine shop where it was magnafluzed, cleaned and resurfaced. it was warped .012" horizontally. So compression mixture was just bouncing back and forth between cylinders on each up stroke and that's why it was not firing. Once reassembled it ran just great.
for a detailed, itemized run down of what I did check the first 7 pages of writing from my Jeep log-book at this link:
http://www.flickr.com/photos/123927...7648206433698/
also the process of the rebuild is there too along with videos of it running again.
Just wanted to share in hopes that this may/could help someone who uses the search feature to diagnose a similar problem
and just a few photos to add :
teardown:
it all looks wet because I was working in a slight rain that day
the head gasket damage:
nasty lifters
pushrods
the repair:
new header bolts
cleaned up and ready for reinstall
head checked, magnafluxed, resurfaced, painted, and valves in
new heater core
ready
rockers guides and studs
IROCZman15 is offline   Reply With Quote Quick reply to this message
Unread 10-14-2014, 10:26 PM   #2
IROCZman15
welp, sorry, It looks like since I do not have over 25 posts to the forum, my photos will not display. however they can all be seen at the link below:
http://www.flickr.com/photos/123927...57648206433698
Unread 10-16-2014, 08:55 AM   #3
DTMOOOO
Nice job, how long did this take & what was the cost. Was thinking of puchasing a 4.0 off a part out to slowly build and keep as a backup
DTMOOOO is offline   Reply With Quote Quick reply to this message
Unread 11-05-2014, 07:26 AM   #4
IROCZman15
all in all it took about a total of 9-10 hours over several different days, but mostly because all of the parts and brackets I took off I degreased and cleaned up, spent a bunch of time replacing the heater core, which requires you to take out the battery, battery tray, and whole heating assembly enclosure underneath the dashboard. also took a while because my neighbors would always stop and chat while I was working, bringing progress to a halt. also, snapped off so many bolts which were just too overstressed and rusty from years of being in the jeep. I also took off extra parts which were not required to replace the head gasket, such as the water pump, lifters, cleaned the timing cover, had to extract a bolt which snapped that held the distributor cap to the distributor, etc
also I have pretty much repaired the steering issue, I drained the old fluid and added all new fluid and almost all of the bumpyness in the steering system is gone. I can notice a slight hard spot when turning the wheel, but its barely noticeable to others
the cost was $275 ish for the machine work on the cylinder head. about two-hundred bucks for the gasket set, lock tite, cooling passage sealant, degreaser and brake-kleen cans, various fittings, injector O-rings, oil, oil filter, power steering fluid, coolant, and also around $60 for the heater core.
Unread 12-08-2014, 11:55 PM   #5
IROCZman15
no need to reply, just finally got a chance to resubmit the photos to the original post. .. I used photobucket this time in stead of flickr and now the photos showed up.
and just a heads up.. I had installed an autozone cheap-o temp-switch and it riddled my brain with problems. it was reading 210 * when my hand held temp devices were nowhere near that (185 ish). just today I bought and installed a OEM temp-switch (in rear of cylinder head) and now my temp readings are correct. so if replacing a temp-switch buy an OEM part
