Head Bolts Replace? - JeepForum.com
post #1 of 5 Old 10-22-2004, 07:59 AM Thread Starter
jedwards
Head Bolts Replace?
Good morning. I just found out last night that the head on the 90 laredo I just bought is warped and the valve seals are bad. The machine shop is going to mill down that head to remove the warpage and redo the seals. I noticed in the chilton manual that is says to replace the head bolts after the second use, should I do this? Where is the best place to get the bolts (chrysler wants $121 for them).
Also the head was already disassembled when I got the jeep, so how do I know which bolt goes where (since there are 4 different types/lengths)?
It also says to use a sealant on each of the bolts and loctite 592 on bolt number 11, any suggestions on what type of sealant?
jedwards is offline
post #2 of 5 Old 10-22-2004, 08:49 AM
gumby
gumby's Avatar
do this
Replace the head bolts you don't have to get them from the dealer. you can buy
Grade 8 or harder bolts from a machine shop or Napa ETC... get a sample from your old ones. should not be that expensive
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline
post #3 of 5 Old 10-22-2004, 09:10 AM Thread Starter
jedwards
Bolts
What about the ones that seem like studs (bolt with thread then a nut then more thread)? Does this type serve a purpose?
jedwards is offline
post #4 of 5 Old 10-22-2004, 03:06 PM
gumby
gumby's Avatar
Threaded studs offer a more even torque application not prone to streching or uneven pulling. because your tightening them down against the head where a bolt is pulling the head down to the block
Robert Frost
gumby is offline
post #5 of 5 Old 10-23-2004, 07:46 PM
75SV1
I think the ones with the threads are for the wire support for the Injectors. There should be two or three black plastic post with a 'C' at the top. These slip over those threaded bolts. On the Newer bolts 96+ (I think), two of them have a post or dowel sticking uo from the bolts. These align the rubber valve cover gasket. It doesn't apply to your year, but just in case.
Tom
75SV1 is offline
4.0 Head Bolts MarineJRM Engines & Drivetrain 2 11-11-2009 06:32 AM
head bolts shawnxj Engines & Drivetrain 2 01-26-2009 05:57 PM
want to replace head unit what do i need titosgreen95yj Audio, CB & Ham Radios, GPS, & Electrical 4 08-29-2008 10:32 AM
4.o head bolts nick94yj Engines & Drivetrain 2 06-23-2007 08:35 PM
Where to get Head Bolts? Bradley Engines & Drivetrain 2 11-29-2005 09:10 AM
