having problems getting into 1st gesr or reverse st a stop. in a 97 wrangler se 5 sp - JeepForum.com
post #1 of 9 Old 11-11-2012, 11:08 AM Thread Starter
chasfer
As the title says I'm ha ving troble shifting into 1st or reverse from complete stop
chasfer is offline
post #2 of 9 Old 11-12-2012, 06:07 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Grinding in reverse and an inability to shift into first at a stop is usually a sign of a clutch that isn't disengaging. I would be looking at the master cylinder, line, or the slave cylinder first. After that, you will need to check the pivot, t/o arm, t/o bearing/ and lastly, the clutch assembly itself.
jeepdaddy2000 is offline
post #3 of 9 Old 11-12-2012, 05:09 PM Thread Starter
chasfer
Thanks jd2000. These are things I thought would be the problem I havent even had a stick in years. Ill deff take the advice
chasfer is offline
post #4 of 9 Old 11-15-2012, 11:28 PM
gearfather
shut the motor off, if it shifts ok then, put a clutch in it.....or adjust yours properly...meaning, make sure that there is not any air in the cyls etc.....
gearfather is offline
post #5 of 9 Old 11-16-2012, 10:45 AM
mdm
Farm Wheeler
Where should he look for the clutch adjustment on a TJ?
chasfer - is the clutch slipping in 4th or 5th if you get happy with the skinny pedal? With the engine running and the rig sitting still, do you have trouble getting into any other gears besides Reverse and 1st?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #6 of 9 Old 11-16-2012, 11:01 AM Thread Starter
chasfer
I only have trouble getting into 1st gear from a complete stop. And reverse.
And I havent experienced any tranny slip. Of course its a 4 banger 97 so its such a pooch I really baby her. Its been lots of fun to drive especially on the 200 acre farm I hunt. Thats a big reasin I bought it. Deer hunting. And 4x4 to pull deer out of the back 40
chasfer is offline
post #7 of 9 Old 11-16-2012, 11:43 AM
mdm
Farm Wheeler
Synchronizers
mdm is offline
post #8 of 9 Old 11-17-2012, 09:42 AM
jeepdaddy2000
1971 CJ5
Originally Posted by mdm View Post
Synchronizers
If it won't go into first, and it grinds going into reverse, then the input shaft is still rotating.
post #9 of 9 Old 11-19-2012, 11:29 PM
gearfather
Synchronizers
reverse doesn,t have a synchronizer.
