Have any of you heard of this? - JeepForum.com
post #1 of 9 Old 07-03-2012, 10:24 PM Thread Starter
flyjeeptings
1990 XJ Cherokee
Was talking to a mechanic over the weekend, and we were talking about blow by on my 90 xj 4.0 and he was saying put tranny fluid in the combustion chamber to soak the rings over night? That should help the rings free up alittle more. Does it actually work?
flyjeeptings is offline
post #2 of 9 Old 07-04-2012, 01:19 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Anything is possible, however, in my experience, blowby is caused by engine wear. The only real way to eliminate it is through cylinder work.
jeepdaddy2000 is offline
post #3 of 9 Old 07-04-2012, 02:14 AM
KMD
1976 CJ7
put too much in and forget to crank it with the plugs out and you will need a new motor anyways. Can not compress liquid. I agree time to do some cylinder work.
KMD is offline
post #4 of 9 Old 07-04-2012, 02:39 AM
jnicewan
His theory might work but its based on if the rings are carboned up and stuck. ATF is a pretty decent solvent and its loaded with detergents. Chemicals like B12 chemtool and seafoam might actually work better. If the blow by is due to worn cylinders or rings you probably wont help a thing other than cleaning the tops of the pistons.
If you have tranny fluid laying around then go ahead and try it since its a free. Get an oil squirt can or turkey baster or something to squirt the oil into the spark plug holes, do all of them. After letting it sit overnight be sure to crank the engine over for a few seconds before installing the spark plugs to blow the oil out and you might throw a couple rags over the holes to save a mess. Put the plugs back in and drive it around for awhile. If it seems like it worked then try it again. If you want to try a more aggressive cleaner, get the B12 or seafoam. You might consider an oil change after youre done because whatever chemical you poured in, some of it might have creeped into the crankcase, the little amount of ATF would be ok, but you might not want an unknown amount of B12 or seafoam in you crankcase/oil.
jnicewan is offline
post #5 of 9 Old 07-04-2012, 10:17 AM Thread Starter
flyjeeptings
1990 XJ Cherokee
Thanks guys I tried it. N I didn't cover the plug holes an got oil allll over my neighbors driveway. But it's all good now! it smoked like crazy for an hour! I can't see my engine being worn that much. It's only got 120 k and maintenance every 3-4 thousand k.
post #6 of 9 Old 07-04-2012, 11:34 AM
KMD
1976 CJ7
LMFAO at oil on neighbors driveway Win!
KMD is offline
post #7 of 9 Old 07-04-2012, 01:39 PM Thread Starter
flyjeeptings
1990 XJ Cherokee
At least it's funy for u guys. It's hurting my wallet and back! 2 bottles of soap, and **** ton of everything else and about 10 L of degreaser I think i got it
post #8 of 9 Old 07-04-2012, 02:03 PM
KMD
1976 CJ7
That sucks. Try some cheap soda pop. The acid can help eat the oil. Also purple power works great too.
KMD is offline
post #9 of 9 Old 07-04-2012, 02:09 PM Thread Starter
flyjeeptings
1990 XJ Cherokee
I got it all! Thanks for the help tho. Now ima go rip around the streets in the jeep!
