Got 10w40 instead of 10w30 is this bad - JeepForum.com
post #1 of 5 Old 10-16-2013, 06:11 PM Thread Starter
longislandxj
1994 XJ Cherokee
Just accidentally put 10w40 instead of the 10w30 it recommended is this really that bad where i should change it?
The oils synthetic
longislandxj is offline
post #2 of 5 Old 10-16-2013, 06:14 PM
jlp437
Nope! No problems Use it for a regular interval and switch back to 30wt if you want.
I pray this doesn't turn into an oil discussion about 4.0's again
jlp437 is offline
post #3 of 5 Old 10-16-2013, 06:21 PM Thread Starter
longislandxj
1994 XJ Cherokee
Ok thanks good thing i don't have to shell out another 47$ for that mistake
post #4 of 5 Old 10-16-2013, 09:09 PM
biffgnar
biffgnar's Avatar
$47! What sort of expensive oil did you put in there? As prior poster said I don't want to turn this in to an oil thread as those get off the rails easy, but that seems pretty high.
Romney in 2020!
biffgnar is offline
post #5 of 5 Old 10-16-2013, 09:22 PM Thread Starter
longislandxj
1994 XJ Cherokee
47 for 6 quarts and filter the oil was mobil 1 from autozone
