GM V8 diesels - JeepForum.com
post #1 of 11 Old 01-22-2006, 03:35 PM Thread Starter
paulhumphries
GM V8 diesels
I've just bought a CJ5 to restore.
In the UK such a vehicle is rare so I'm going to have to adapt rather than just go to the local dealers for a lot of parts.
The engine is missing and I want a diesel unit - preferably with autobox.
It's been suggested that I use the old GM 6.2, 6.5 or 6.7 diesel V8 as they are a common engine and easilly avaliable out of vans. They are used in Range Rover conversions (although the torque destroyed gearboxes ) which means better spares avalibilty that a lot of US engines over here.
I've been trying to find out a little about them and came across a discussion forum which basically said they weren't very good and why do the British fit them !
What is this list opinion of this engine and suitabilty (with autobox) for a CJ5.
Thanks.
Paul Humphries,
Stoke-on-trent,
Staffs.,
UK.
paulhumphries is offline
post #2 of 11 Old 01-22-2006, 10:32 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Weight is always an issue with diesel conversions. I have the feeling that the GM unit is going to be a bit much in that department. Most diesel conversions for CJ's consist of four bangers. Americans running diesels, as a whole have not been impressed with the GM 6.2 and 6.5 motors. With the Ford and Dodge offerings far out powering them, most buyers overlooked them when making a choice for a power plant. Auto transplants in 5's are always a dicey project, especially in pre 71 units due to the drive trains overall length. Careful measurements of the proposed drive train need to be taken, or you will wind up with a extremely short rear driveline.
jeepdaddy2000 is offline
post #3 of 11 Old 01-22-2006, 11:14 PM
Bgeddes
Bgeddes's Avatar
1978 CJ5
I drove GMC Suburban 6.2 for 125,000 miles. In a vehicle whos gasoline counterpart would get 15mpg at best, I routinely made 30mpg. I was far from fast, but, far from powerful. I regualrly towed cars on trailers behind the truck, in that capacity, it excelled. As Jeepdaddy said, the GM diesels are heavy, very heavy. They are also huge, and to get the power to the ground, the drivetrain must match. I can't think of a capable auto trans that would give you any acceptable driveline angle. Fullsize trucks in the States are long, and so is thier drivetrain. Good luck.
'00 XJ Classic > Stock DD
'88 Grand Waggy - Bone stock pseudo-barnfind
'78 CJ5 - Under minor rehab
Bgeddes is offline
post #4 of 11 Old 01-23-2006, 02:15 AM Thread Starter
paulhumphries
Thanks for replys.
I think I'll forget that idea then !
I've got a 2.5 VM diesel of the same type fitted to Cherokee so will try and adapt that and stick with manual gearbox.
I've a "bad" left leg and although I can, and do, drive manuals I prefer autos.
What I have got, sitting unused in a box, is an auto clutch conversion. I bought it for my Land Rover Discovery but it'll now pobably end up on the Jeep.
I assume you have them in the US but for those who don't know what they are it's a device that operates the clutch dependant on engine speed, road speed, whether braking etc so you don't need to touch the clutch pedal. You still change gear manualy but other than that a small control unit feeds the clutch in and out. You have a button on the gear knob to operate it manualy if the auto operation isn't fast etc enough.
Paul Humphries,
Stoke-on-Trent,
Staffs.,
UK.
post #5 of 11 Old 01-23-2006, 05:56 AM
jeepdaddy2000
1971 CJ5
Paul, application is everything. With a mild lift and no real expectation of flogging it off road, an auto can be done. Other tricks are to space the engine further forward in the engine bay. Just remember that length is an issue, and needs to be addressed early on. By the way, what year is it? Seems that there are a few folks transplanting Diesels into Jeeps on the earlycj5.com forum, as well as the binder bulletin(IH's). While your swap might entail different powerplants, you might want see if they have any advice on adapters and bellhousing patterns.
For some reason Americans have been late to embrace diesels. The new units being offered by various manufactures in light trucks are in most cases, better in every way when compared to their gas counterparts. My wifes Ford F350 4x4 crew with the powerstroke will outdo it's gas cousin in every way.
post #6 of 11 Old 01-23-2006, 10:40 AM
Bgeddes
Bgeddes's Avatar
1978 CJ5
That 2.5VM diesel would fit into a CJ5, even and early one. They come with an auto (5sp) here in the states, that option might be easier than converting the clutch. I own a Diesel Liberty (Cherokee on your side of the pond) and I thnk that motor would EXCELL in a CJ. The KJs weigh in at 4000lbs plus, so the CJ should really fly with the diesel. Even better, at 300lb-ft of torque, drive line issues should be easier to address. Remeber to take lots of pictures, keep a detailed parts list, and post progress here!!! Thanks.
Bgeddes is offline
post #7 of 11 Old 01-23-2006, 11:26 AM
Fullsize_CJ5
The big thing about GM diesel v-8 engines is the fact they were actually gasoline engines converted to run on diesel. The had many issues. Nothing on the engine was actually heavy duty enuff to hold up to the abuse a diesel engine sees even under "normal" conditions. A diesel engine has much higher compression, and needs bigger stronger parts through out. The gas conversions just never held up.
79 CJ 5, fiberglass tub on a cut down full size chevy frame. Full width axles GM 14 bolt in the rear. Dana 60 up front both with 5.38 gears. 350/400 turbo, np205 transfer case. Custom built modified 3 link rear coil spring suspension in the back, skyjacker leafs in the front. 44X18.5 gumbo mudders. 104" wheelbase hood and doghouse stretched 13" . ramsey 8000lb winch.
Fullsize_CJ5 is offline
post #8 of 11 Old 01-23-2006, 03:59 PM
Bgeddes
Bgeddes's Avatar
1978 CJ5
This is only true for the very early ones. Oldsmobile was guilty of this also. When I owned my 6.2 I also owned BB & SB Chevys and none of the accesory brackets etc would bolt onto the Diesel. The block and heads were different. It was my understanding the 6.2 is a Detriot. I didn't wear the 6.2 out in 225,000 miles, the last 80K spent dragging a loaded car trailer around. I am certain any gasoline engine would have been done long before 200,000, especially worked like dog pulling the trailer.
Bgeddes is offline
post #9 of 11 Old 01-23-2006, 05:37 PM
jeepdaddy2000
1971 CJ5
The engine you speak of is the 5.7 used in auto's. The 6 liter engine family is a different engine altogether. GM always seemed to be behind with their diesel technology till they offered the duramax. Because of this, their sales of diesel equipped full sized trucks always lagged.
post #10 of 11 Old 01-27-2006, 12:44 AM
violatedppl
mybe the duramax is so good because its not really a gm deisle. If I remember right its a mitsubishy ( I know its spelled wrong) engine, When my dad was looking at a gm or ford he told me about it. Also I have heard alot of problems with the early duramax engines so....
14 jkur expo and mild wheeler
violatedppl is offline
post #11 of 11 Old 01-28-2006, 04:02 PM
dsl4me
1979 CJ5
The dmax is a joint venture with Isuzu.
Most of the 'rumored' problems never occured with the dmax. The early ones did have injector issues but GM extended the warranty to 200K on those. Want to talk about problems, bring up the Ford 6.0L. Ford went public and stated a $500million warranty cost to that line along with many buybacks.
The 6.2/6.5 was also intended for 1/2 ton trucks, something the IH/Cummins never was.
dsl4me is offline
diesels coldfire0914 Engines & Drivetrain 2 10-13-2008 11:12 AM
Diesels in Jeeps Revisited paulchilds Engines & Drivetrain 15 07-16-2003 08:00 PM
