GM 5.3 or 5.9 dodge manual tranny??nv3500? - JeepForum.com
post #1 of 4 Old 09-20-2010, 01:25 PM Thread Starter
jrodum
What are the best donor vehicles for this v-8 swap with a manual transmission? Any come stock with the nv3500??
My 2.5L went to crap on me at 80,000 and I am looking to upgrade to a v-8. The dodge 5.2L or 5.9L swap seems pretty good and the 5.3L GM swap also has been mentioned. I am looking to keep the np231 for the time being (I really donít have the money for an atlas) and am also going to get an 8.8 for the rear. I will need to change the input shaft of the 231 to 23 spline. I would like to keep it a 5 spd and still be able to drive on the interstate with it. It looks like if I pick up a nv3500 it will be good for either GM or dodge swap. I have been on the novak site and looked around a ton, but still havenít figured out which one to go with GM or dodge.
01 TJ, 5.3L LM4 4l60e lokar shifter, np241C with JB conversions SYE, Carolina Driveline F+R driveshafts, taurus fan + griffin radiator, 33" Destinations, D30 ballistic brackets + 8.8 + MAD brackets, SOLID diffs, 3.5" RE lift discos + CAs ,1" BL, magnaflow muffler Panasonic reciever, Infinity speakers / Tweeters, 2 Rockford Fosgate 8's, Herc'd grill and tub, LOD rockers, Hella fogs, LOD front shorty bumper w/custom tube, Rear Bumper/ Tire Carrier + LOD frame tie-in bracket, Warn xd9000i
jrodum is offline
post #2 of 4 Old 10-10-2010, 06:06 PM
JaceCJ5
1978 CJ5
I personally have thought about the 4x4 S10's...they come with a 4.3 V6 and a NV3500. If you dont want a V6 you can put a 350sbc in with the same NV3500 from the S10.
JaceCJ5 is offline
post #3 of 4 Old 10-16-2010, 11:42 PM
private
On that note. I recall somewhere that the rear half of the Jeep 231 can be adapted the front half of the Chevy 231 without any problems (although I'm curious as to how the shifter linkage would work (unless this is on the 93 back chevy 231s cause the 94+ use a shifter cable).
1998 TJ 2.5 5spd
private is offline
post #4 of 4 Old 10-25-2011, 10:37 PM
LilSteve97TJ
What happened to your 2.5l? Do you still have it?
97 TJ
98 Taco
LilSteve97TJ is offline
Manual tranny options for AMC 360? GeologistFelix Engines & Drivetrain 5 10-03-2009 09:10 PM
Will 5.2L bolt to an np435 Tranny from a dodge truck? spcmac249 Engines & Drivetrain 0 08-02-2009 11:31 AM
Dodge np 208 t-case and a TF999 tranny? AuroraJeep Engines & Drivetrain 2 02-27-2009 01:09 PM
which manual tranny for built I6? A-man930 Engines & Drivetrain 11 10-15-2007 01:19 AM
Manual Tranny Recovery bigjohnwhodatis General Jeep & Off-Road Equipment 3 12-03-2003 11:55 AM
