getting 4wheel linkage through bushing hole? - JeepForum.com
post #1 of 7 Old 05-08-2012, 10:38 PM Thread Starter
jeepish59
shear pin came out of linkage and came out of the nylon bushing. Must be an easier way to get that dang thing through that hole. Makes me wonder how I helped procreate three kids. Hmmm. KY jelly? Orrr...Maybe I didn't?
Any other advice would be appreciated. On the nylon bushing.... I have the other one figured out.
jeepish59 is offline
post #2 of 7 Old 05-09-2012, 02:30 AM
relgnarw
I used WD-40 and a pair of pliers. It should pop in with a little effort. I'm talking about the linkage of course.
"I had wobster at Wed Wobster" - Austin age 5
My onboard air build.
relgnarw is offline
post #3 of 7 Old 05-19-2012, 03:00 PM Thread Starter
jeepish59
wd40
And the prize goes to relgnarw. I decided not to you KY but used your suggestion instead and it worked like a charm. Thanks. I feel stupid for not thinking of it.
But now I have an additional question I'd like to bounce off you. 4wd linkage connected. now no reverse, starts in park and neutral, feels like it wants to go forward while in reverse but goes forward fine in OD, D 1, 2. Might be unrelated but.... I am medium talent shade tree mechanic but new to 4X4 so I have little knowledge of linkage and transmission system of the 4's. Just recently learned you have to have four tires the same size. So I am that new.
And if based on what I have told you you are going to tell me my tranny is shot, well, if you write back talk about the weather or something. anything but having to replace the tranny.
I lived in Massolon (It was a huge sports town back then, late 70's) and Canton for a while. I followed the Amish carpenters around painting houses. Just what we would have if the Amish built cars and trucks. Hmm. At the very least they would get the mileage they claim on the sticker but probably not electric radios or seats. At least they would have a place for my shovel.
Thanks again
Ish
post #4 of 7 Old 05-21-2012, 02:56 AM
relgnarw
I knew a tranny once....... Seriously though, now it sounds like a transmission linkage issue. If you are sure you have the transfer case linkage good to go, check the transmission linkage. I'd disconect it from the trans and manually shift it to park, and adjust the cable in or out until it shifts correctly.
As far as the Amish goes, I've never seen a 4 wheel drive buggy. Yeah, I'm about 10 minutes north of Canton, right now the weather is great but that could change in a second.
relgnarw is offline
post #5 of 7 Old 05-21-2012, 09:21 AM Thread Starter
jeepish59
flashy tranny
I worked at a place in Atlanta. saw this beautiful jeep tranny, tall and lanky, long curley hair half way down her back, over six foot tall. Asked the security guard about her. "Oh. You mean him?" When you cant tell the difference you know you know you have lost your mojo. Ya ever seen that commercial on you tube about wedding night? check it out...
Did as you suggested. was only about a quarter inch off but I could not figure out how to adjust the dang thing. is a quarter inch enough to make it malfunction? have some time today will look it over again but here is what i found today.
have a buddy helping me today. maybe i can figure out a way to bypass linkage and shift through gears without being under it or standing in front of it and getting run over.
also did the key on and off got codes 12 and 14. would map sensor have anything to do with this?
I also checked the gear selector to make sure what gears are in drive and if there is neutral. all positions put it in drive, even neutral. It will however start in the neutral position but when it does it will take off right away which is exciting. all forward gears work and while driving it shifts through all gears including OD. park does not move forward but you can tell there is a little pressure on the plate.
I have been trying to trace a vacuum leak down that was making it idle high. I think I found most of it but still think I have a bit of a leak unless it is just the computer readjusting things over the last 30 miles.
I had to put an engine in it this winter so I am trying to work out the bugs and no reverse, starting in neutral and immediately launching are big bugs.
be nice if one adjustment fixed all the glitches.
Thanks for your help so far.
ish.
post #6 of 7 Old 11-23-2013, 02:25 PM
Garrett2go
My 4 wheel drive won't engage this is a picture of the linkage I think the bushing is missing because it keeps slipping out of the opposite side
Garrett2go is offline
post #7 of 7 Old 11-23-2013, 03:20 PM
AMA-JEEP
same problem
I had almost an identical problem but my only problem is the 4WD, when we did my 6" lift apparently the bushing where the linkage goes in to the frame the link did not align perfectly in the hole and finally came out, I wonder if they have a drop down bracket where it's placed lower to match the diff height.?? I hope I'm making sense on the description. It was a pain in the butt to put it back in.
This is after replacing it back in into the frame holder, any advise on this and do they make a bracket to lower that down from the frame?
/l ,[____],
l--l--()lllllll()-
()_)-()_)--o-)_)
AMA-JEEP is offline
How to get into 4Wheel Competitions li'l jeep General Jeep & Off-Road Equipment 1 09-14-2011 06:47 PM
Popping In Front End When In 4wheel lilhogge General Jeep & Off-Road Equipment 5 02-06-2010 11:24 PM
Transfer Case will not grab 4wheel hi... jbrown78cj7 Engines & Drivetrain 2 01-11-2009 04:01 AM
Trouble with 4Wheel Parts?? FredBull General Jeep & Off-Road Equipment 11 04-20-2007 10:57 AM
Warn x8000i and 4wheel parts franco802 General Jeep & Off-Road Equipment 7 12-13-2004 10:06 AM
