Quantcast Gears question - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Gears question
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 07-16-2009, 07:44 PM   #1
mreeves28xx
Gears question
I have a '06 TJ and was wondering how you can tell what kind of gears you have? Also the type of axles? Anyone able to shoot me in the right direction to look for these?
mreeves28xx is offline   Reply With Quote
Old 07-17-2009, 08:09 AM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The TJ Forum FAQ in the TJ Tech Forum has these answers.
Here are some links:
Which axle(s) do I have?
How do I determine my gear ratio?
And another thread with info:
Stock TJ Specifications
98 TJ
Wheelin98TJ is online now   Reply With Quote
Old 07-17-2009, 08:18 AM   #3
hotrod351
1955 M-38
if all else fails then tape a long string to the bottom of the driveshaft, push the jeep forward, or backward, until the tire makes 1 full rotation, look and see how many times the string wrapped around the driveshaft. 3 & 1/2 times would be 3:50 and so on and so on. if you have a posi then you can just jack up the rear and turn the tires one turn, because they will both turn in the same direction and amount.
hotrod351 is offline   Reply With Quote
Glock Forum
