Gears - JeepForum.com
post #1 of 11 Old 05-22-2012, 10:06 PM Thread Starter
caiha
Gears
Have 09 wrangler unlimited x. I put 2inch lift and 33 tires on and on the hwy it sucks gas and rpm is between 3000-3500. What gears should I install to correct this problem. Not sure what's in there now. Maybe 323
caiha is offline
post #2 of 11 Old 05-22-2012, 11:33 PM
scubamc
Is it an automatic or standard?
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 11 Old 05-23-2012, 09:33 AM Thread Starter
caiha
Automatic
caiha is offline
post #4 of 11 Old 05-23-2012, 10:03 AM
Jason
You should shift out of second gear.
Jason is offline
post #5 of 11 Old 05-23-2012, 04:07 PM Thread Starter
caiha
It's automatic dude
caiha is offline
post #6 of 11 Old 05-23-2012, 04:52 PM
Jason
Originally Posted by caiha View Post
It's automatic dude
There's no way in hell you're turning 3000-3500 RPM at highway speed with 31s and 3.23 axle ratio. Unless you're in second gear. Or your highway's speed limit is 150 MPH.
Dude.
Jason is offline
post #7 of 11 Old 05-23-2012, 10:48 PM
02crewcab
he running 33's man, not 31's
02crewcab is offline
post #8 of 11 Old 05-24-2012, 06:56 AM
Jason
Even better. There's still no way in hell he's turning that many RPM with a normally functioning transmission.
Jason is offline
post #9 of 11 Old 05-24-2012, 12:03 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
And what do bigger tires do to your RPM?
Wheelin98TJ is offline
post #10 of 11 Old 05-24-2012, 12:09 PM
Wheelin98TJ
JEEP FREAK
Your auto trans has a 0.69 overdrive ratio.
If you have the deepest factory ratio available for a JK (4.10), you would be doing 100 MPH at 3k RPM and 115 MPH at 3,500 RPM.
Something is not adding up.
post #11 of 11 Old 05-24-2012, 12:59 PM
edpmedic
http://www.onlineconversion.com/bigger_tires.htm
At the bottom calculation you can figure out the conversion for metric tires to inches
http://pitbulltires.com/calculate.php
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
