Gear ratios - JeepForum.com
post #1 of 11 Old 04-26-2012, 07:30 PM Thread Starter
carbiz
Gear ratios
I just bought a 2003 wrangler x 5 speed and don't know ratio to change gears too? It has
DANA 35/194MM rear axle
Dana 30/186MM front axle
With 3.07 gears in my jeep now. I am putting a 6" lift I think with either 35x13.50's or 37x13:50's
So what ratio gears do I need?
carbiz is offline
post #2 of 11 Old 04-27-2012, 02:08 PM
Jake03TJ
Bigger axles if you wan to run 35' or 37's.. I don't wheel a lot, when I do wheel it is usually winter wheeling, and I run 33's and have 4.11"s and have no issues..
ΜΟΛΩΝ ΛΑΒΕ
Jake03TJ is offline
post #3 of 11 Old 04-27-2012, 02:58 PM
Jason
4.88, but consider some upgrades / replacement for the rear axle.
Jason is offline
post #4 of 11 Old 04-29-2012, 10:55 AM Thread Starter
carbiz
So like a whole new axle? I probably won't be wheeling much just driving
carbiz is offline
post #5 of 11 Old 04-29-2012, 07:06 PM
BlueRubiconrich
pickup a copy of June 2012 JP mag some good info you should read on axles.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #6 of 11 Old 04-30-2012, 06:27 PM
armmata
1991 XJ Cherokee
4.88 would be the best bet
armmata is offline
post #7 of 11 Old 04-30-2012, 06:32 PM
Jason
Either an entire replacement, or significant upgrades to your current axle.
There are enough reported failures on-road to make it a good idea even if not going off-road.
Jason is offline
post #8 of 11 Old 04-30-2012, 10:00 PM
crazyYJ93
Hey got a question what you think a good axle shaft kit I was thinking the chromoly kit for my dana 35 axle what you think ?
crazyYJ93 is offline
post #9 of 11 Old 05-01-2012, 12:27 AM
armmata
1991 XJ Cherokee
If your upgrading find a dana 44
armmata is offline
post #10 of 11 Old 05-01-2012, 07:19 AM
Jason
I'd look at Superior's stuff. The 30-spline axle kit and C-Clip eliminator specifically. If you're not wheeling, that should put you in good shape.
Jason is offline
post #11 of 11 Old 05-01-2012, 07:20 AM
Jason
Easier said than done. And if you find one, you'll dearly for it.
For a complete axle replacement, a 8.8 is a an effective solution in most situations.
Jason is offline
