I have a 98 TJ with stock gearing. I currently have about 3.5-4 inches of lift with 33x12.5 tires. Ive been told its recommended to change the gearing. I don't know much about this topic and don't want to waste money buying the wrong item. Please help me out all advice is appreciated.
I have the same problem guess I thought they would help here but i guessed wrong. If you find anything out pm me plz and I will do the same thanks!! Sarah::cheers2:
I have a 98 TJ sport. It is a 5 speed manual with a 4.0L and im not sure what its geared at. id assume stock since i have never changed it if "stock" can be the correct term as i am not sure if they have different gear ratios for different wrangler models.
If it originally came with the 28" tires and a D35 axle it is most likely the 3.07 Gears.
4.10 would match RPMs with 33" Tires but do to the extra weight and wind resistance of a lifted Jeep most will go 4.56 to get it up into the power band on the highway and give a better crawl in 4lo.
That is what I will be doing if the true trac limited slip I have on order ever shows up (8 weeks so far)
Jeff
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
