Gasket? Water pump? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Gasket? Water pump?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Boss is away but Erin is here to STAY with a F.Y.S. SaFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-12-2015, 06:37 PM   #1
Taylort
Gasket? Water pump?
So how screwed am I on this? Just noticed a leak from the front of the engine on the drivers side. Seems to be the pink orange coolant. Worst thought an intake gasket? Water pump is near by but hard to tell. Anyone have any experience with this issue? Possible prices? Asking for advice before I head to the shop.
Taylort is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 09:47 PM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Poke your noggin under there and see if this is what is happening.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2015, 02:42 AM   #3
Taylort
No not one bit! These ever known to leak from the left cylinder head plug? On the other hand looks a lot like a head gasket
Unread 03-14-2015, 09:25 AM   #4
Taylort
From the picture it appears to be wet above the head gasket up near the power steering pulley. I have noticed some minor belt squeak almost un noticeable. Is there a plug in that area that could be leaking? I'm just trying to convince myself it's not a head gasket it hasn't showed any other symptoms besides the leak.
Unread 03-15-2015, 09:45 PM   #5
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Try this:
Thanks for your post.
We’re here to help, but you must understand that all Jeeps are not the same.
In order for us to give you more accurate advice and help, we must know the following, as applicable, along with detailed information as to the symptoms/problems etc:
Year
Model
Engine
Transmission
Transfer case
Unread 03-17-2015, 06:33 AM   #6
Taylort
Jeep Grand Cherokee Laredo
2005
4.7L V8 engine
