gas type - JeepForum.com
post #1 of 6 Old 07-28-2005, 03:42 PM Thread Starter
speedracer2536
gas type
this isnt about jeeps but my freind just bought a 96 m3 bad *** car and he was curious with gas prices and all if he could put regular and not supreme in it
speedracer2536 is offline
post #2 of 6 Old 07-28-2005, 03:51 PM
urwaker
2007 WK
my dad has a brand new 325 ci and he told me never put anything in it other than suprmeme. I guess the guy at the dealer told him that if you go with anything less than that, youll hurt the engine. I guess something with the perfectly fine tuned engine in a BMW and the temperature it runs at, that they require the higher grade gasoline. i wouldnt risk it thats for sure. at the least youll lack hard core power and gas mileage. thats just what ive been told.
urwaker is offline
post #3 of 6 Old 07-29-2005, 09:06 AM
denverd0n
Actually, if it doesn't cause any ping or knock, you'll get BETTER power and gas mileage by using a LOWER octane fuel. You should use the lowest octane fuel that runs well in your engine.
denverd0n is offline
post #4 of 6 Old 07-31-2005, 01:38 AM
Night Wolf
The thing is, on a newer engine, it has a knock sensor, so if there is knock, the computer will retard the timing to prevent it, so you won't hear it, if you do, then it has to be pretty bad.
While I do not like BMW that much, it is still an expensive somewhat luxury car, you don't drive one of them to be cheap on parts and maintenance, and the whole $2/fill up really isn't worth it, if the manufacter says to use premium gas, then I would strongly recomend that you use it.
The Caddy requires Premium, and that is all she has ever got, I don't think twice about it... it is a premium luxury car so naturally it'll need a little more then a typical Chevy.
Night Wolf is offline
post #5 of 6 Old 07-31-2005, 12:58 PM
TJVigilante
The M3 has an 11:1 compression ratio, I wouldn't go with anything less than 93 for maximum performance.
TJVigilante is offline
post #6 of 6 Old 08-05-2005, 02:44 PM
algoesfast
The octane rating is an anti nock rating. With high compression engines and engines with power adders ie turbo, superchargers and nitrous should use high octane. Due to the fact that detonation can accure other wise. The higher the octane rating the higher the flash point or heat needed to ignite. 87 octane needs less heat were 93 requires more to ignite. So the lower octane is fine in lower compression engines. But if I was your friend and didn't want to blow my engine up and have to fight the dealer to try to get them to fix it. I would stick with high octane fuel. Whatever the manual says.
algoesfast is offline
type of box reeln77 Audio, CB & Ham Radios, GPS, & Electrical 7 01-08-2010 09:24 PM
what type of rim is this? 98cherokee19 Tires & Wheels 8 08-04-2009 06:19 AM
So what type of amp would you run? jeep95riogrande Audio, CB & Ham Radios, GPS, & Electrical 3 08-01-2009 11:48 AM
What type sub? rpx13 Audio, CB & Ham Radios, GPS, & Electrical 11 10-13-2007 06:22 AM
Any one know what type of rim this is? Luda Tires & Wheels 0 07-19-2007 11:12 AM
