Gas Mileage - JeepForum.com
post #1 of 20 Old 05-31-2007, 07:56 PM Thread Starter
Black03TJ
Gas Mileage
I'm looking to max out gas mileage on my jeep and willing to spend the money to do it. I have an '03 Wrangler Sahara with 31" BFG AT's. I'm getting a little more than 16 MPG with this set up. I've heard of several things that will possibly increase the mpg (intake, exhaust, header, etc... ) wanted some suggestions especially if you have one of these upgrades.
UNDER CONSTRUCTION
Black03TJ is offline
post #2 of 20 Old 06-01-2007, 11:16 AM
curtjames37
curtjames37's Avatar
Save the money you are going to spend on these mods and put them into the tank. The mileage gains are so small with the mods you mentioned that it will take a long time for them to pay for themselves let alone save you money.
I don't know what the stock gear ratio or stock tire size is on a TJ but it is possible that the 31s are stealing a few MPGs.
curtjames37 is offline
post #3 of 20 Old 06-01-2007, 11:41 AM
KrazyGimp
1982 CJ5
I really doubt that you are going to see anything much above 16. I wish my motor was even close to that. As stated above, those mods will not get you where you want, and if you just go bolting on random parts that are not matched together you can hurt your millage instead of help. Maybe find a gear ratio calculator (go to www.4lo.com) and mess around with that to see what you can do with your gearing, but don't get too exited.
You are driving a Jeep after all, not a Civic.
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
post #4 of 20 Old 06-01-2007, 11:53 AM
Test
2007 WK
Want to max out your mileage? Buy a Toyota Prius.
Test is offline
post #5 of 20 Old 06-01-2007, 01:55 PM
RockScar
I get 15.5 in my 84 cj7 on 33's and 4.10 gears and basicly stock 4.2. Ha!
RockScar is offline
post #6 of 20 Old 06-03-2007, 06:39 PM
gearheadjlm
gearheadjlm's Avatar
I managed to get 20mpg today. That was A/C off, 5th gear, 2200 rpm, level ground, cruise set at 70mph, for 200 miles. This is a first ever for me. There was one time through west virginia on I77 I averaged 14.5, most of the time around 16, 17 if I am lucky. This is stock 4.0, stock gears, and 32x11.5 tires. This is calculated by topping off tank, setting trip, then at next top off, dividing gallons by miles....
I'm wondering if this engine properly built with a turbo would do better....
gearheadjlm is offline
post #7 of 20 Old 06-04-2007, 07:33 PM
heywaitfourme
20ish here, but I only run around town, with 31's, stock gears and a 4.6 stroker. Good luck getting something to be happy about if you drive the highway.
2011 Grand Cherokee 4x4 black on black w/hemi
heywaitfourme is offline
post #8 of 20 Old 06-10-2007, 05:13 PM
DamianDeBe
Actually, highway mileage should be much better that in stop and go traffic, unless you are flooring it all the way. I see at least a 4 mpg increase in milage on the highway.
DamianDeBe is offline
post #9 of 20 Old 06-10-2007, 08:16 PM
4.7stroker
Funny my milage goes down 1mpg on the highway????
I average 16mpg in town and if I keep it at 60 on the highway (which I don't)
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #10 of 20 Old 06-10-2007, 08:37 PM
curtjames37
Aerodynamics are a *****.
post #11 of 20 Old 06-14-2007, 04:36 PM
aszalan
aszalan's Avatar
buy a scanguage II and see if you change the way you drive, accelerate, etc makes a difference
aszalan is offline
post #12 of 20 Old 06-14-2007, 05:19 PM
flatlander757
Wranglers are about as aerodynamic as a barn, I wouldn't expect great highway mileage, best would be probably cruising around 2600rpms at 60mph with cruise control on... it's way steadier than your right foot
flatlander757 is offline
post #13 of 20 Old 07-04-2007, 12:40 PM
AJE
The only thing I really did to my XJ is a poor man's cold air intake. I'm not sure if it helped or not.
The other big thing is keeping your tires inflated to the correct psi. You ever tried to pedal a bike with low tires?
AJE is offline
post #14 of 20 Old 07-04-2007, 01:23 PM
ElvisV04290
ElvisV04290's Avatar
fold your windshield down, and get some ski goggles
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #15 of 20 Old 07-09-2007, 11:04 PM
bobbert350
bobbert350's Avatar
yea id say also save ur money any mpg u get out of it will take forever to recoupe the money you spent on them....you gotta stop thinking miles per gallon and think fun per gallon...i get ****ty gas mileage 12 around town 13 on the high way but i dont care i get a heck of a lot of fun per gallon....
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
bfg mt km mileage and tsl radial mileage epeck87 Tires & Wheels 1 03-29-2009 08:53 AM
LTB Mileage SkyChi Tires & Wheels 7 10-27-2008 07:10 PM
4.10/4.56 gas mileage? morningwood1429 Engines & Drivetrain 18 02-08-2008 10:17 PM
AT vs/MT mileage? terrible Tires & Wheels 3 04-02-2006 01:00 PM
Gas mileage JeepnTX Engines & Drivetrain 3 03-07-2003 03:45 PM
