Gas/air ratio - JeepForum.com
post #1 of 6 Old 12-09-2011, 07:05 PM Thread Starter
tdeal74
Gas/air ratio
I have an 05 TJ, 4L, bolted on new air intake, throttle body spacer, stage one chip. I'm wondering if I need to reflash the CPU to ensure proper gas to air ratio. Sub question, new MAP sensor required?
Also, anyone running headers to a cat-back exhaust? If so, pros & cons?
tdeal74 is offline
post #2 of 6 Old 12-09-2011, 07:25 PM
ajmorell
ajmorell's Avatar
No, the current sensors should allow the AFR to run around stoichiometric (14.7)
ajmorell is offline
post #3 of 6 Old 12-09-2011, 07:35 PM Thread Starter
tdeal74
Cool, so you went a lil over my head but if I understand you correctly, the CPU will adjust itself. In other words the electronics will do their jobs and correct the ratio. Thanks for the input!
tdeal74 is offline
post #4 of 6 Old 12-09-2011, 11:46 PM
jnicewan
Speed density systems can only make small adjustments to fuel trim and they only do that on a warm engine and other than wide open throttle (closed loop). Basically saying you can make minor engine enhancements, or add minor bolt-ons to the engine and the computer may be able to compensate as long as the oxygen sensor picks up the difference. The oxegon sensor is not used on a cold engine or during wide open throttle.
jnicewan is offline
post #5 of 6 Old 12-12-2011, 11:03 PM
444
I wouldn't worry about it. Those aftermarket intakes on most vehicles don't make any difference other than sound anyway.
444 is offline
post #6 of 6 Old 09-11-2013, 05:44 AM
jeepter
I would agree just changed back from a cold air pod filter to the standard air box concerned the after market pod no suited too off road use with no differences apart from sound .. !
jeepter is offline
