Fuel system cleaners - JeepForum.com
post #1 of 8 Old 04-26-2012, 04:28 PM Thread Starter
chicagohusker
Have any of you used those engine cleaners that you pour into the gas tank(not sure of the official name) and is supposed to clean the system and improve mpg? I saw a few on amazon for cheap and not sure if it'll help, or if it'll even ruin my engine. If you used, which one would you recommend?
I have a 05 Cherokee with 72k miles, and my mpg is about 13 city and 15 highway, was thinking of using a cleaner and see if it'll help improve my mpg.
chicagohusker is offline
post #2 of 8 Old 04-26-2012, 06:54 PM
Ricke92cj
I've used blaster fuel injector cleaner for awhile now. It does improve gas mileage back closer to factory, but mainly gives you more power that the dirty injectors have robbed you of.
Ricke92cj is offline
post #3 of 8 Old 04-26-2012, 10:25 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Nothing like BG 44K. Period.....
cruiser54 is offline
post #4 of 8 Old 04-26-2012, 11:46 PM Thread Starter
chicagohusker
I looked that bg one up, looks easy enough to use. All you have to do is pour it in when tank is empty, then refill tank and drive around and it cleans itself?
post #5 of 8 Old 04-27-2012, 12:27 AM
jnicewan
There are plenty of decent additives out there but I will mention 3. BG-44k, Seafoam, Lucas. I wouldnt waste money on the cheaper products either. Read the directions on what you choose but most of these products are used at fill up or work best with at least 10 gallons of fuel or so. Dont expect any chemical to be a miracle cure though, if a problem is suspected it may actually need a real flush or at least multiple treatments.
What I like about Seafoam is the multiple uses the product has. You can use it to clean the fuel system, run it through the intake/ throttle body to clean the intake and valves, run it through the crankcase along with other uses. Seafoam will also stabilize fuel for up to 2 years for storage just like sta-bil, it will also take moisture/water out of the fuel system just like HEET. Do a search on here about Seafoam, plenty of people here have used it with good results.
jnicewan is offline
post #6 of 8 Old 04-27-2012, 06:29 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pretty much it. It isn't cheap but it is very effective at cleaning injectors and carbon deposits from the back of intake valves and the combusion chambers.
post #7 of 8 Old 05-05-2012, 12:40 AM Thread Starter
chicagohusker
Went the seafoam route, poured a bottle of it into my gas tank, drove from lincoln Nebraska to Chicago and was getting 20mpg+ for most of the trip, that made me a believer that that stuff works.
post #8 of 8 Old 05-05-2012, 10:24 AM
wendell
1987 YJ Wrangler
The best engine cleaner is sea foam brand, it's the real deal.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
