Fuel Pump? - JeepForum.com
post #1 of 7 Old 05-04-2013, 07:01 AM Thread Starter
Jimh64
Fuel Pump?
I do not hear the fuel pump coming on when I turn the ignition. For some reason I cannot get the engine code using the key on/off technique.
Do I have to drop the fuel tank to test the fuel pump? If so, how do I use an meter to test it? I have a meter,but I'm not exactly sure how to use it in this instance.
Please help, thanks!
Jimh64 is offline
post #2 of 7 Old 05-04-2013, 11:03 AM
GilaMtnJeep
GilaMtnJeep's Avatar
The key on-off process does not work for your jeep since you most likely do not have OBDII. As for the pump you should start by checking the fuse. If it is good, find the relay and swap it with an identical one, that will rule that out. After that you need to see if there is power to the pump. I don't know the wire colors and a diagram would be most helpful to you.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 7 Old 05-04-2013, 11:50 AM Thread Starter
Jimh64
To check for power to the pump, how can I get to the connector since it is probably on top of the tank? I guess I might have to drop it?
Sorry for so many questions
Jimh64 is offline
post #4 of 7 Old 05-05-2013, 01:24 PM
GilaMtnJeep
Maybe not. If you know the wire colors you may find a connector somewhere towards the rear to test at. This is where a wiring diagram is handy.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #5 of 7 Old 05-07-2013, 01:17 PM
TURNIPHEAD
i recently changed my fuel pump in the tank ( mind you it was a toyota pu) but the principles are the same . you can activate the pump by getting a small 12v battery and tapping into the fuel pump wires with the vehicle off, Or you can uese a hot tester and locate which wires get hot once the engine cranks over . hot i mean by recieves 12 v + there is normally a circut opening relay that is activated once ign on is activated by the key right before you actually crank over the engine. I highly suggest having a wiring diagram any time you do any electrical work . avoid the haynes manuals or chilton its a waste try to find a oem manual or diagram ,
TURNIPHEAD is offline
post #6 of 7 Old 05-07-2013, 03:20 PM Thread Starter
Jimh64
Thanks for the info! I think I am going to tackle the project this weekend. I'm going to drop the tank and start there.
Jimh64 is offline
post #7 of 7 Old 05-12-2013, 12:45 PM Thread Starter
Jimh64
Well, I can't believe it, but it was a 30amp engine control fuse!
I could not see the break in the fuse, but my nephew has better eyes!!
I'm so glad that I didn't drop the tank! Maybe this will help someone else.
Have someone with "good" eyes check all your fuses lol!
Jimh64 is offline
