-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   fuel problems (http://www.jeepforum.com/forum/f19/fuel-problems-1357681/)
slickonetwo 04-16-2012 09:07 PM
fuel problems
Got bad gas dropped tank cleaned it out cleaned fuel pump assembly blew out lines put all back together wont start...fuel pump turns on with key tried on and off key cycle to prime system but have no pressure at fuel rail have spark will run a few seconds with starting fluid...over half tank of gas...fuel pumps out when line disconnected at pump dont know what to check now ...fuel filter clogged?
jnicewan 04-16-2012 10:48 PM
Take line off before and after fuel filter, also try that at the fuel rail too. If you had bad fuel and cleaned all that stuff up then why didn't you replace the fuel filter. You should put a new filter on it for sure but might want to see if you are getting fuel to the filter first.
The time now is 02:17 AM.
