Fuel problem - JeepForum.com
post #1 of 5 Old 10-18-2006, 11:59 AM Thread Starter
SEZARO21
Fuel problem
I'm having the problem where my jeep just shut off or won't want to start. It will turn over it just won't start. I tested my fuel pressure yesterday and the fuel pressure is where it should be w/ and w/out the fuel regulator vacuum atached, 31-40 PSI and 41-49 PSI. The Haynes manual said that when I turn the jeep off the pressure should drop 0-20 PSI. That means that the pressure w/ the jeep off should be around 20-31 PSI. Well when I turn the jeep off, the pressure drops to zero. That is way below what it should be. What is wrong with the jeep. What should I replace. Please help as I need the jeep ready for it's first real offroad trip this weekend.
1991 2.5L YJ, 4" R.E. lift kit, 1-1/4" Lift shackles, K&N CAI, 4.0 TB w/ bored out intake, 5.0L Ford Mustang fuel injectors, 117A alternator, Ford Taurus electric fan, Rancho steering stabilizer, 8.8 Ford axle, 35x12.5x15 Dunlop Mud Rovers, Smittybuilt Titanium side steps, Smittybilt SRC Front Grille Guard Bumper, Smittybilt Stereo Center console, PIAA 520 Series fog lights, Sylvania Silverstar headlights, 20 gallon fuel tank upgrade & Herculined tub.
SEZARO21 is offline
post #2 of 5 Old 10-19-2006, 03:58 PM
jadams68
jadams68's Avatar
Are you getting power and fuel to your injectors?
Are you getting spark?
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 5 Old 10-20-2006, 12:11 PM Thread Starter
SEZARO21
i'M GETTING SPARK AND PRESSURE
SEZARO21 is offline
post #4 of 5 Old 10-25-2006, 09:48 AM
JEEPINWI
Check your distributor cap for cracks. With the lights out, have a buddy turn over the engine and look for stray sparking near the cap. My YJ did the same thing...I had fuel and spark, but engine would not start. Turned out to be a cracked cap.
Brian-
99 XJ Cherokee, 2 door, 4.6L Stroker, 5 speed, 4x4, 8.25" rear, 3.07 gears
JEEPINWI is offline
post #5 of 5 Old 10-26-2006, 07:56 AM Thread Starter
SEZARO21
I replaced the fuel pump and the jeep now holds pressure like it should but when shut off but it still stalls out. I'm going to see if the cap works. Will let you guys know. Oh. just wanted to mention that I missed my off road trip. Well maybe next time.
SEZARO21 is offline
Problem with fuel pump. BIGGS000 Engines & Drivetrain 8 08-21-2008 01:51 PM
Fuel pressure problem TSEJEEPERS Engines & Drivetrain 0 11-25-2006 01:34 PM
93 YJ 4.0 HO fuel problem JeepCherokeeFan Engines & Drivetrain 1 07-20-2006 09:10 PM
Fuel pressure.. problem? martyb Engines & Drivetrain 3 02-25-2003 04:19 PM
Fuel Problem Mysta_Killa Engines & Drivetrain 1 10-24-2001 02:40 PM
