Fuel Problem - JeepForum.com
post #1 of 2 Old 10-23-2001, 08:05 AM Thread Starter
Mysta_Killa
Fuel Problem
I have a 84 Wagoneer with a 2.5 engine. My problem is there is fuel in the oil, what is the cause of this? Bad fuel pump? Bad carb? anyone else have this problem? Thanks!
Mysta_Killa is offline
post #2 of 2 Old 10-24-2001, 02:40 PM
glm 87 wrangler
sounds like the carb. It seems to be flooding
out.Check or have someone check the carb.your float maybe sticking.Does it run ok or does it try to cut off,can you smell fuel.Would like more info..on how it runs..
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
HELP!! 4.0 fuel injector problem famous1688 Engines & Drivetrain 5 11-03-2008 02:19 PM
Fuel pressure problem TSEJEEPERS Engines & Drivetrain 0 11-25-2006 01:34 PM
Fuel problem SEZARO21 Engines & Drivetrain 4 10-26-2006 07:56 AM
93 YJ 4.0 HO fuel problem JeepCherokeeFan Engines & Drivetrain 1 07-20-2006 09:10 PM
360 Fuel \ Exhaust problem EvilJackBall Engines & Drivetrain 3 04-03-2004 07:14 PM
