Fuel injected to carbed motor - JeepForum.com
post #1 of 4 Old 03-18-2014, 05:34 PM Thread Starter
bigredyj
I am going from a fuel injected 2.5l to a carbureted 350 olds motor and am wondering what I have to do in trm of fuel delivery to my current gas tank and fuel lines.....any info would help.
Thanks
bigredyj is offline
post #2 of 4 Old 03-18-2014, 06:41 PM
BlueRubiconrich
For starters you might need a fuel regulater.and or you might have to check the tank and see what kind of pressure it sends.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 4 Old 03-19-2014, 07:24 AM
unobtanium
Thanks
I did this on a mustang 5.0. I had a 190 LPH fuel-pump, and the stock fuel-lines for EFI. I left them both alone. IT never had an issue even shifting at around 7K rpm. (huge cam, etc.) Never fuel-starved the bowls.
Every fuel-system is different. Just dialed the FPR down to 10-12 I believe it was. It didn't burn up the pump because it was a return-style fuel system. no harm, no foul.
Traded the '10 WK w/Hemi and QD2 in on 5/15/15 for a '15 mazda CX-5 2.5L AWD Touring. Happier!
unobtanium is offline
post #4 of 4 Old 03-19-2014, 09:23 AM
kaitlynsdad
if your running a mechanical fuel pump i would remove the pump in the tank and extend the pickup
kaitlynsdad is offline
