front wheels locked up - JeepForum.com
post #1 of 3 Old 10-01-2012, 09:15 AM Thread Starter
pinky123
1978 CJ7
I have a 1978 CJ_7 with quadra trac I am new to jeeping so I need all the help I can get my front wheels locked up on me while driving what could it be also I dont like the quadra trac and would like to change to manuale locking hubs to engage the 4 wheel drive is this doable
pinky123 is offline
post #2 of 3 Old 10-01-2012, 03:33 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
[QUOTE=pinky123;14241967]I have a 1978 CJ_7 with quadra trac I am new to jeeping so I need all the help I can get my front wheels locked up on me while driving what could it be [QUOTE]
Not much information...
The emergency drive is engaged.
Mismatched gears between the front and rear diff.
You can try to find a mile marker part time kit. They have been discontinued, but a used unit would still work.
Swap in a D18 t case from an early CJ. You will have to buy an adapter. It can get rather expensive.
jeepdaddy2000 is offline
post #3 of 3 Old 10-02-2012, 08:00 AM
mdm
Farm Wheeler
You need to figure out where it is locked up. Transfer case or axle. Will it roll with the transfer cas in Neutral?
Do you have a locker, LSD, or an open differential?
Jack up the front and remove the front drive shaft. Will the wheels turn? Are the brakes seized? Pull the differential cover and look for damage.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
TT rear / locked front stokerdog Engines & Drivetrain 1 05-13-2012 08:02 PM
Locked front and rear in snow Agony Wagon General Jeep & Off-Road Equipment 19 10-06-2011 12:37 PM
aussie locked front/rear stuckonstocktj Engines & Drivetrain 7 07-20-2010 12:52 AM
99 cherokee front brakes locked? SPK Cheap Tricks & Fixes 2 05-23-2010 12:01 PM
locked front or rear? mytj General Jeep & Off-Road Equipment 21 02-26-2005 06:46 AM
