Quantcast Front Pinion Seal Leak - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Front Pinion Seal Leak
Old 03-04-2006, 09:43 AM   #1
Jeep'n
Have started noticing that my front pinion seal is leaking, was told that once you lift Jeeps that if the angle of the front drive shaft is not 100% correct this will be an ongoing problem, the thing is, North Shore Off Road here in Vancouver assures me that the angle is correct as they did the mods so my question to you is what else could be causing this and what are my options to prevent this ?
Thanks
Ross
It's Better to Burn Out Than Fade Away
Jeep'n is offline   Reply With Quote
Old 03-04-2006, 01:16 PM   #2
BigWaylon
tubework is cool...
BigWaylon's Avatar
you could have a simple leaking seal to replace, or your bearings could also be bad...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Glock Forum
