Front locker vs. rear locker - JeepForum.com
post #1 of 17 Old 04-06-2008, 05:37 PM Thread Starter
airtraffic007
I am looking to purchase a Detroit locker but only have enough to buy one. Is it better for rock crawling/trailing to get a locker in the front or the rear?
airtraffic007 is offline
post #2 of 17 Old 04-06-2008, 05:49 PM
ajmorell
ajmorell's Avatar
How about some more info, like the vehicle it is going in, are you running a lift, what size tires, axles, etc.
ajmorell is offline
post #3 of 17 Old 04-06-2008, 05:54 PM
GibsJeep
I say the rear......Check out this link, read through it and scroll down to headline ''which axle to lock first.''
Link- http://www.stu-offroad.com/misc/locker-1.htm
GibsJeep is offline
post #4 of 17 Old 04-06-2008, 05:55 PM
GibsJeep
That would help too...
GibsJeep is offline
post #5 of 17 Old 04-06-2008, 06:42 PM
jason m
Nothing but the facts
jason m's Avatar
if its trail only then lock the rear you break less or you could put the locker up front and just weld the rear. like all the others said more info is needed about your rig, jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #6 of 17 Old 04-06-2008, 09:45 PM Thread Starter
airtraffic007
I've got a '01 Wrangler Sport...Dana 44 rear and 30 front. 4" suspension lift and 33x12.5 tires. Still have the factory gearing though...need to upgrade that too.
post #7 of 17 Old 04-07-2008, 09:43 AM
ajmorell
ajmorell's Avatar
Well if you are planning on regearing, I'm not sure I would spend the money on a locker now unless you already have at least 3.73 gears from the factory. The reason I say this is that most lockers (at least full-case ones) have a carrier break (typically 3.54 down, and 3.73 up).
What I would probably do if you really want a locker is go with something like an Aussie, which isn't a full case locker and would work with any gear set and I would put it in the 44. The 44 will hold up to 33s better locked (although both should be fine) and if you ever have to engage 4wd on the road it will handle much better.
ajmorell is offline
post #8 of 17 Old 04-07-2008, 10:24 AM
element981
Not to Hi-jack, but how would an Aussie in the rear and an ARB in the front do?
Chris
2005 LJ Rubicon w/Savvy Under Armor
Jarhead Jeep Club member #17
Colorado Jeep Club member #119
July 14, 2008
RIP Danny Dupre SSgt/USMC
element981 is offline
post #9 of 17 Old 04-07-2008, 10:38 AM
Black Hills TJ
Black Hills TJ's Avatar
I personally wouldn't put a lunchbox in the rear if you drive it on the road. Just my .02. ARB/Detroit in the rear and Aussie up front.
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out
Black Hills TJ is offline
post #10 of 17 Old 04-07-2008, 10:55 AM
element981
I've read Aussie up front when in 4wd and in snow on the road is a no no?
Chris
July 14, 2008
post #11 of 17 Old 04-07-2008, 12:28 PM
Chris_
Just fine.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #12 of 17 Old 04-07-2008, 01:52 PM
ajmorell
ajmorell's Avatar
A Detroit functions in basically the same way a lunchbox does. I understand the argument for an ARB because it is selectable, but other than being a full case locker, a Detroit doesn't offer much upgrade over a lunchbox IMHO
ajmorell is offline
post #13 of 17 Old 04-07-2008, 11:22 PM Thread Starter
airtraffic007
"Well if you are planning on regearing, I'm not sure I would spend the money on a locker now unless you already have at least 3.73 gears from the factory. The reason I say this is that most lockers (at least full-case ones) have a carrier break (typically 3.54 down, and 3.73 up)."
What is a carrier break? Does this mean that regearing would be useless if I get a locker (I'd like to get 4:56 gears)? Just curious...
post #14 of 17 Old 04-08-2008, 06:23 AM
ajmorell
ajmorell's Avatar
It depends on the current gears you have and what lockers you want to go with.
ajmorell is offline
post #15 of 17 Old 04-08-2008, 08:53 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
A "carrier break" refers to an axle using a different carrier/locker for different gear ratios.
The "carrier" is what the ring gear bolts to. Its the locker if you have a full case locker (ARB, Detroit, Ox, etc.).
Your D30 has a carrier break at 3.55/3.73 meaning that the axle uses the same carrier/locker for 3.73, 4.10, 4.56, or 4.88. 3.55 or anything numerically lower requires a different carrier/locker.
Your D44 has a carrier break at 3.73/3.92. So 3.92, 4.10, 4.27, 4.56, 4.88, etc. all use the same carrier/locker.
To add to the confusion, there are "thick gears" available for your D44. Thick gears allow you to use the numerically lower gear ratios (3.73, 3.55, 3.27, etc.) on the 3.92 and numerically higher carrier/locker.
Make sense?
Wheelin98TJ is offline
Front vs. rear locker 97Xj_Sport General Jeep & Off-Road Equipment 5 11-07-2005 05:40 AM
OX Locker on both front and rear wen-chi lee General Jeep & Off-Road Equipment 11 08-29-2005 09:31 AM
Locker, front or rear? andreas970 General Jeep & Off-Road Equipment 22 06-01-2005 09:14 PM
front vs. rear locker Dr Gutiemouth General Jeep & Off-Road Equipment 11 06-21-2004 07:41 AM
Locker: Front or Rear?? 93jeepyj2.5 General Jeep & Off-Road Equipment 35 08-10-2002 03:53 PM
