Front end U joint replacment - JeepForum.com
post #1 of 3 Old 11-24-2012, 06:19 AM Thread Starter
mnkjoe
The U joint on my 1997 jeep grand cherokee 5.2, 4x4 all time is going out. I was wondering if anyone had any good write ups on the replacement.
Thanks for the help!
mnkjoe is offline
post #2 of 3 Old 11-24-2012, 09:00 AM
Oldjeepman
There should be some on here .Did you use the search? Look under the zj tech and search there are some write ups also check FAQ.section . I did my daughters xj last month wasn't to bad just takes time also I replaced both unit bearings since one was going out..I used spicer u-joints and timken bearing
Oldjeepman is offline
post #3 of 3 Old 11-24-2012, 09:16 AM Thread Starter
mnkjoe
Yeah ive searched through them but i cant seem to find a FRONT DRIVESHAFT u-joint replacement guide.
mnkjoe is offline
drive shaft , u-joint , write up , write-up
