Front driveshaft vibration - JeepForum.com
post #1 of 6 Old 07-11-2012, 06:10 PM Thread Starter
hamor
i've got an 04 Rubicon with The Rubicon Express lift. The 5 speed trans was replaced with a 6 speed. It has a bad vibration over 65. if i pull the front drive shaft it goes completely away. replaced the u joint and still there. anyone had this problem.
hamor is offline
post #2 of 6 Old 11-09-2012, 06:53 PM
JeremyA
Dd you get it figured out? I have been having front end vibration for months now and can not find it. I have changed the pinion angle countless times. Put new u joints and centering ball in the front shaft. If you remove the front shaft it goes away. I may have the balance checked on it next.
JeremyA is offline
post #3 of 6 Old 11-10-2012, 07:19 AM
biffgnar
biffgnar's Avatar
This should be your next step. If that doesn't fix it consider bent output shaft on the TC.
Romney in 2020!
biffgnar is online now
post #4 of 6 Old 11-19-2012, 07:56 AM
JeremyA
It was just way out of balance. Having the drive line shop balance it took most of my vibrations out. I know there is still a little in the rear drive shaft but its not that noticeable and the pinion angle looks good as well as the ujoints so I'm not going to worry about it right now.
JeremyA is offline
post #5 of 6 Old 11-19-2012, 08:18 AM
mdm
Farm Wheeler
...I know there is still a little in the rear drive shaft but its not that noticeable and the pinion angle looks good as well as the ujoints so I'm not going to worry about it right now.
At what point will you start worrying about it? When the u-joints wear out? When the drive shaft comes apart? When the seals on the transfer case or pinion start leaking? Rotating parts don't like vibration and they will find a way to make their displeasure known.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #6 of 6 Old 11-19-2012, 10:13 AM
Millermagic
This.
Killed my front pinion seal and bearing by running too long with a vibration in the front.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
Rebuilt Front Driveshaft + Removed Rear DS = Vibration Gone... what to do w/ Rear DS? pmarascal Engines & Drivetrain 9 09-21-2010 04:48 PM
Ford Ranger driveshaft vibration jp360cj Engines & Drivetrain 5 10-02-2009 09:56 PM
driveshaft vibration vespucci Engines & Drivetrain 1 10-15-2006 05:57 AM
Driveshaft Vibration Rory621 Engines & Drivetrain 1 04-04-2006 02:27 PM
New Lift, SYE, Driveshaft and vibration moabster Tires & Wheels 10 07-26-2002 11:30 PM
