Freezing, need heat, help! - Page 3 - JeepForum.com
post #31 of 44 Old 01-08-2014, 05:06 PM
brouwmat
Originally Posted by 2tall2slow View Post
the other doors must work. going through the modes on the switch(defrost, floor, etc) all work just fine.
Then if the modes work fine and the blend door isn't broken it either has to be the heater core or the thermostat. See my previous post.
Sent from AutoGuide.com App
brouwmat is offline
post #32 of 44 Old 01-08-2014, 05:19 PM Thread Starter
2tall2slow
So you suggest its a possible bad thermostat or heater core? I was under the assumption that if my thermostat was faulty, coolant would not flow to the heater core at all. Being that my hoses are hot, i am confused.
2tall2slow is offline
post #33 of 44 Old 01-08-2014, 07:19 PM
brouwmat
How hot is hot? Can you hold onto them for any amount of time without being seriously uncomfortable?
To be honest, I recently went through the same thing and thought my hoses were hot too. However, I also noticed that my guage was running a little cooler than it normally was as well. I swapped the thermostat and now it is seriously hot. I cannot hold onto it at all when it reaches operating temp.
My thermostat was faulty and not opening at the right temp. - that was my problem but a partially clogged heater core can cause issues like this as well. I knew that wasn't my problem because I had recently replaced mine.
brouwmat is offline
post #34 of 44 Old 01-09-2014, 06:38 AM
vadslram
If the air coming out of the vents at low fan speed isn't close in temp to the coolest hose connected to the core then your blend door is wonky.
The relative temps of the coolant going into the the core and whether your thermostat is faulty are a completely different story.
vadslram is offline
post #35 of 44 Old 01-09-2014, 07:18 AM Thread Starter
2tall2slow
I grabbed onto hoses and after a few seconds i had to let go, they were that hot. After work today i plan on replacing thermostat. Its pretty cheap and it cant hurt, maybe i will get lucky. It sure is cold outside. Tired of driving bundled up sitting on my hands.
post #36 of 44 Old 01-09-2014, 11:38 AM
vadslram
I think you are wasting time and money with the thermostat.
A bad one would either be stuck closed keeping the flow from the radiator and making the engine overheat or stuck open making the engine take longer to come up to heat.
If the hoses are too hot to hold on to then you have enough heat present to heat the cab. You can confirm by running with a piece of cardboard in front of the radiator, that will up the heat without spilling antifreeze all over.
vadslram is offline
post #37 of 44 Old 01-09-2014, 11:42 AM Thread Starter
2tall2slow
I think you are right. Going to backflush the core 1st. That wont cost me much time or money. Maybe theres some gunk needs out. I noticed a slight build up yesterday under my cap.
post #38 of 44 Old 01-09-2014, 04:59 PM Thread Starter
2tall2slow
Got it!
post #39 of 44 Old 01-09-2014, 05:13 PM Thread Starter
2tall2slow
I chose to flush the heater core myself before spending anymore time and money. It was a lot easier than I expected. Out came a dark sludge and finally clear water. I reattached hoses and fired up my jeep with heater on wide open. I was so cold that I couldn't tell if it was warm or not, so my wonderful wife relieved me when she said yes, it was blowing hot air! I need to thank brouwmat, vadslram, and everyone in between. Couldn't/wouldn't have attempted the task without all the insight. Thanks for the confidence build guys, I feel like a champion.
post #40 of 44 Old 01-09-2014, 07:02 PM
brouwmat
Congrats!
brouwmat is offline
post #41 of 44 Old 01-24-2014, 08:05 AM Thread Starter
2tall2slow
After successfully flushing my heater core, and heat coming out now, I have had a new problem. My windshield is fogging for no reason, and I am smelling this sweet smell inside of my cab. It was suggested to me t hat my heater core actually needs replaced now? Say it aint so..
post #42 of 44 Old 01-24-2014, 09:52 AM
vadslram
Sorry but I think that stuff that was clogging your core was also plugging a leak. It isn't that bad to replace and not too expensive either. Then you can make sure the blend door is working right and all the weather stripping is in good shape.
vadslram is offline
post #43 of 44 Old 01-24-2014, 12:56 PM
brouwmat
Yep. That is your heater core. Wjjeeps.com is your new friend. Plan on at least 8-10 hours to do it. It isn't bad, just a lot of work. Anyone can do it if you are proficient with tools.
brouwmat is offline
post #44 of 44 Old 01-24-2014, 06:32 PM Thread Starter
2tall2slow
Great.
