A free engine buuut.. - JeepForum.com
post #1 of 2 Old 03-23-2014, 12:27 PM Thread Starter
jonbpc
1993 XJ Cherokee
Hello , i was recently given a 4.0 litre , fully rebuilt , found the build sheet it was rebuilt as an "off road performance" engine. Upon opening it up i was in shock!
Its been sitting for some time and unfortunately the elements did some damage..
i looked in the cylinders doesnt look to bad, ive started soaking them in oil . was going to start spraying all the engine to try to remove it.
Am i wasting my time . should i just pull it all apart? apperciate any suggestions
thanks Jon
jonbpc is offline
post #2 of 2 Old 03-23-2014, 01:27 PM
relgnarw
thanks Jon
WOW it looks like it was in a lake for a while.
No, you're not wasting your time. If it was me I'd completely tear it apart and inspect everything. Put a fresh hone to the bores, replace the bearings if need be. Check everything and evaluate.
"I had wobster at Wed Wobster" - Austin age 5
My onboard air build.
relgnarw is offline
