found a star bolt in transmission pan om the magnet. 5.9 jeep - JeepForum.com
post #1 of 9 Old 09-01-2013, 01:48 AM Thread Starter
Alotaglock
I found a 1/2 inch long pretty skinny star head bolt in my transmission pan attached to the magnet while doing a trans filter change. I checked to see if it went anywhere I could see on the bottom of the transmission. I couldn't find any missing screws. The transmission has never had the pan dropped as far as I could tell or filter changed. It has 110,000 miles. Has anyone else ever found a screw in the bottom of the oil pan? Every thing seams to be working fine but I have never seen a bolt back out in a transmission. I did notice some small metal shavings in there too. Mostly feel like grains of sand connected to the magnet. A long with a few slivers that are really thin. Not sure if I should be alarmed.? I did see a lot of the exact same screws in the bottom of the transmission but no missing screw holes were found. Thanks for any replies, Aaron
Alotaglock is offline
post #2 of 9 Old 09-01-2013, 07:37 PM
uberxj92
1992 XJ Cherokee
Wow. Never found a bolt in a Tranny pan. But the sandy textured metal sounds normal. I gave found slivers before but like maybe 2 or 3 tops.
I would take it to a Tranny shop (not aamaco). Show them the bolt.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 9 Old 09-02-2013, 03:42 AM
mmerlinn
Never found any bolts loose in a pan before, but I did find a screwdriver once.
There are no star head bolts in any Jeep transmission except for the center support bolt in the TH400 Jeep. And that bolt is an inch long with 3/8" star head although the head is actually called a 12-point (double hex) head.
mmerlinn is offline
post #4 of 9 Old 09-02-2013, 10:56 AM
GilaMtnJeep
GilaMtnJeep's Avatar
Over the years I have found maybe 5 or 6 "foreign objects" in trans and engine pans. All but one I chalked up to dropped into the pan somewhere during the assembly line. The one time I did attribute it to a failure was from a connecting rod bolt that came loose (rod end failure).
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #5 of 9 Old 09-08-2013, 11:23 AM Thread Starter
Alotaglock
It's a star or hex or Allen head. Which ever those little bolts are that hold together the valve body. Finally got my jeep off the Jack stands with the full exhaust and all the fluids changed. Seems to still be shifting good and its not making any bad noises. Could have been dropped in there in the assembly process. Thanks for the replies. Aaron.
post #6 of 9 Old 09-08-2013, 04:40 PM
mmerlinn
In my world those are not bolts. They are screws. The difference being if they have a male head they are bolts and if a female head they are screws, so they are screws to me. Yes, I know different areas call things different names, so maybe somewhere your terminology is correct, but in the last 6 decades I have never encountered such terminology. Hex head bolts. Torx head bolts. Torx head screws. Allen head screws. Phillips head screws. Frearson head screws. And so on.
mmerlinn is offline
post #7 of 9 Old 09-13-2013, 06:35 PM Thread Starter
Alotaglock
Good point! In my world, screws come to a point and bolts come to a flat head.
post #8 of 9 Old 03-09-2015, 04:03 PM
BlakeCary
I have a 42re and just did a filter change and the 2 bolts for the filter are a torx head slim screw.
BlakeCary is offline
post #9 of 9 Old 03-10-2015, 08:39 AM
Airstreamer67
The only thing I ever found in a tranny pan was a plug-like piece of plantic in a Ford Crown Vic. I thought I had really screwed this thing up and got on the Internet to see what I did wrong. I discovered that everybody had found one when pulling the Crown Vic pan for the first time. It seems the factory had put that temporary plug into the hole where the oil fill port enters the tranny in order to prevent contamination. When the car is completed, the tranny dipstick is inserted, knocking the plug out into the tranny pan, ready to be found later by the poor panicked bloke who does the first oil and/or filter change. Thanks, Ford.
Airstreamer67 is offline
