Ford injectors in 4.0???????? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Ford injectors in 4.0????????
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 04-20-2006, 09:17 PM   #1
BeerMonkeY
i read where some one put ford injectors in a 4.0 (dont remember from what engine) and it runs better cause the ford atomizes(sp?) the fuel better and has a better spray pattern than the stock ones. anyone ever heard of this
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline   Reply With Quote Quick reply to this message
Unread 04-21-2006, 09:39 AM   #2
75SV1
They use the 5.0 injectors (Bosch). Try Five-O Motorsports of Hyperjective. Might also look at Dinos site.
Tom
75SV1 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2006, 12:10 PM   #3
strokinout
Most people do this when they are in the process of stroking a 4.0L because of the increased demand for fuel.
Ever sneezed with Copenhagen in?
Now looking for a another Jeep soon
In memory of:
1997 Jeep Wrangler 6-cyl.
1994 Jeep Wrangler 4-cyl.
strokinout is offline   Reply With Quote Quick reply to this message
Unread 04-21-2006, 12:39 PM   #4
75SV1
They use the 24-24 lbs-hr injectors for the Strokers. He should use 18-19 lbs-hr injectors for a Stock motor.
Tom
Unread 04-21-2006, 12:51 PM   #5
strokinout
Tom
Yeah, I just read your thread about the grooves in the squish area. VERY interesting. If I ever find the time, I will prolly end up giving this a try. What could it hurt, anyway.(ritorical)
In memory of:
Unread 04-21-2006, 01:05 PM   #6
75SV1
I looked at the MPG website a bit. I saw a simple mod on spark plugs. You need copper electrode spark plugs. You cup out the electrodes and drill a hole through the metal arm (is that anode). I need to get me Jeep running. Both my Contours take Platinum plugs. I might try the cuts latter on too. Looks easy.
Tom
Unread 04-21-2006, 01:38 PM   #7
strokinout
I never would have thought somethin' so easy would produce those kind of results. Thanks for the link to the site.
In memory of:
Unread 04-21-2006, 02:15 PM   #8
75SV1
I'd have some bit of skeptisism though. Still, the spark plugs would be worth a try. Also, if you can change stuff back or make sure you use the same seasonal fuel and from the same station. I've noticed 2-3 mpg from different gas.
Tom
Unread 04-21-2006, 07:06 PM   #9
BigWaylon
tubework is cool...
BigWaylon's Avatar
Bruce is always good to deal with at 5-0...
I ran some FMS injectors in my supercharged Dodge 5.9L...
they do make direct replacement injectors for the Jeep:
http://www.fiveomotorsport.com/Injector_SetsJEEP.asp
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote Quick reply to this message
Unread 04-24-2006, 08:25 PM   #10
Traveller
You don't have to use Ford specific injectors. You can use Bosch, Holley, or Accel injectors, choosing whatever size best suits your needs.
BTW, if you need big injectors, you can use old turbo T-bird or Cougar injectors, which are rated at 36 lbs/hr. You can find these for next to nothing in junkyards everywhere.
Traveller is offline   Reply With Quote Quick reply to this message
Unread 04-27-2006, 08:21 AM   #11
de6w6it
A lot of time when these high lb injectors are used, the motor will run slightly rich, so there is a mod where you build a small circuit that attaches inline with the MAP sensor to be able to adjust the input voltage to the MAP sensor, thereby allowing you to adjust the pulse length of the injectors. There are a few write ups, do a search for adjustable MAP sensor, or electrical mods, I built one, haven't installed it yet, if anyone wants me to make them one for a small small fee, PM me.
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:http://www.yotatech.com/f191/de6w6it...-lemon-190657/
de6w6it is offline   Reply With Quote Quick reply to this message
Unread 05-06-2006, 10:50 AM   #12
Dirty Grand
Tom
If you have 21# injectors in a '95, and if he has a '97, he would have 23#, why would you want to go with 18-19#? Wouldn't it be better to use the 24#? If not, what if you were to change the cam, would that change things?
Dirty Grand is offline   Reply With Quote Quick reply to this message
Unread 05-09-2006, 12:20 PM   #13
Cue-Ball
I run the 24# FMS injectors in my stroker and they seem to be fine so far.
Need to pull the plugs and look to see if it is running lean/rich still though.
'96 ZJ 4.6 Stroker | 42/46RE Hybrid Trans
Link to pix
Big plans, little cash
If my wife asks, tell her I found it on ebay for $50.
Cue-Ball is offline   Reply With Quote Quick reply to this message
