Ford Fuel Injectors in the 4.0HO? - JeepForum.com
post #1 of 3 Old 08-05-2002, 06:32 PM Thread Starter
evilpsych
evilpsych's Avatar
Hey guys.. there's a rumor floating around that Ford Fuel Injectors are a direct swap in for the existing injectors on the 4.0 HO.. I've read this on two or three sites and want to hear from someone that's actually done it.
It sounds like a good idea to upgrade the stock injectors to ones capable of more flow.
When you add things like high-flow air filters, larger throttle bodies, and high-flow exhaust, I think we may be maxing the stock fuel injectors out and ending up with a lean condition in the motor, leading to early engine failure because of the increased temperatures.
If you go to a larger rate injector (the stock on the 4.0 is 15lbs i hear) then you can reach higher HP and torque readings than normal, especially if you're considering supercharging it.
I will try to get ahold of some 19lb Ford Mustang Injectors and let you know how it comes out. Anyone that's done this, please lemme know how it came out and your setup.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 3 Old 08-06-2002, 12:30 AM
91XJLimited
91XJLimited's Avatar
I've heard that the GT injectors do, but i'm not sure that the regular ones do or not. I have no clue if they are the same or not, but like I said, I have only heard of the GT injectors being a swap. I think they are 25 lbs.?
91 XJ Limited - RE 5.5" XD, 32x9.50 TSL's, 4.0 HO, disconnects, other good stuff
94 ZJ 5.2 Limited - 6.5" Teraflex lift, Clayton Long Arms, disconnects, 37x12.50 SSR's, Hummer Beadlocks, and more good stuff
91XJLimited is offline
post #3 of 3 Old 08-06-2002, 12:35 AM Thread Starter
evilpsych
evilpsych's Avatar
ok did a little more research.. turns out.. FI's on different years were different rates and PSI's from the fuel pump.. for mine.. the 25lb @39psi is what i need because the stockers are 23lbs or something..
A
Ford injectors for jeep al666 Engines & Drivetrain 4 02-06-2007 12:47 AM
Ford injectors in 4.0???????? BeerMonkeY Engines & Drivetrain 12 05-09-2006 12:20 PM
Fuel Injectors ojingalena Engines & Drivetrain 0 02-06-2005 09:40 AM
ford injectors bj-666 Engines & Drivetrain 2 02-20-2004 08:40 AM
ford injectors Quan Engines & Drivetrain 6 10-12-2003 01:20 PM
