Ford 9" swap help - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Ford 9" swap help
Bds fox ipf 2.0 racing series shocks now available at rockIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Unread 07-15-2012, 05:10 PM   #1
ktw23
Ford 9" swap help
So I think its time for some new axles on my TJ. I am currently sitting on 33's but I want to upgrade to 35's/37's in the near future without having to worry about things breaking. For the rear I was think of a shaved Ford 9" with 4.88s possible 35 spline with Detroit locker. I'm unsure about clearance since I will be running 33's for the meantime. Would I be able to run 33's or should buy the tires at the same time. Also is it an necessity to use a HI9 3rd member or would an lp with proper pinon angle be fine since I don't play in the rocks, only trails and washed out climbs
2002 TJ 4.0, 4" Pro Comp on 33x12.50's 3.73's D30 & D44 - Daily Driver
1995 YJ 4.0, 4" Rough Country on 33x12.50's 3.07's D30 & D35 - SOLD
1994 ZJ 5.9 Laredo - SOLD
Just Empty Every Pocket
ktw23 is offline   Reply With Quote
Unread 07-15-2012, 06:32 PM   #2
biffgnar
biffgnar's Avatar
Consider a fabbed 9" rather than regular 9" housing. Much better set up. In fact I think there is a thread on Pirate right now with plenty of people expressing opinions about this.
In the rear a low pinion setup stronger, with the possible exception of a True Hi-9 (if you are prepared to spend that money).
2013 NORRA Mexican 1000 - Co-Driver #199
2012 King of the Hammers - Hammerking Productions "Intern"
HELP KEEP JOHNSON VALLEY OHV AREA OPEN: http://www.savethehammers.org/
biffgnar is offline   Reply With Quote
Unread 07-15-2012, 06:44 PM   #3
ktw23
Could you please post that link? I was looking into a currie housing. Any others you could recommend ?
Unread 07-15-2012, 06:48 PM   #4
biffgnar
biffgnar's Avatar
Here's the pirate thread I was thinking about: http://www.pirate4x4.com/forum/showthread.php?t=1078552
Currie fabbed housings are nice. I run one in the rear.
Unread 07-15-2012, 07:22 PM   #5
ktw23
Is there anything wrong with the stock housing n 3rd member. Id prob stick to 35s
Unread 07-17-2012, 07:06 PM   #6
ktw23
I am also going to try and learn how to regear the 9" third member myself. From what I have heard its a good one to start with. I have seen a few good right ups but I was wondering if anyone had a link to a video or something very detailed to help me.
Thanks
Unread 07-17-2012, 09:40 PM   #7
rjnorman
you could also try john at www.9inchfactory.com cheaper than currie just as strong
rjnorman is offline   Reply With Quote
Unread 07-17-2012, 10:34 PM   #8
ktw23
Thanks. I'll have to take a look at what he has
