Ford 8.8 weird sound/Gear Problem - JeepForum.com
post #1 of 2 Old 09-11-2012, 12:39 PM Thread Starter
JSR789
Just installed a Ford 8.8 that I bought bolt in ready and I'm getting a whine/rubbing sound coming from the rear. I popped off the diff cover and found that 2 teeth on the Ring gear wear ground down I'm guessing for clearance for the cross pin. I was told this is not a problem. Could this be the cause of the sound I'm hearing? I asked a local 4x4 shop and showed them a picture of the gear and they said I should be worried riding the truck as is. What do you all think?
JSR789 is offline
post #2 of 2 Old 09-11-2012, 01:06 PM
mdm
Farm Wheeler
When putting 4.56 or 4.88 gears in a 8.8 you have to either notch the ring gear teeth or the cross pin. Notching the teeth is what most folks do.
I don't remember how far across the top of the tooth I cut when I did mine but I don't think it went as far as yours. I don't remember the notch extending as far into the contact area as yours does.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
Please help weird sound 9jeepcherokee5 Engines & Drivetrain 2 07-06-2012 05:22 AM
Weird sound it first gear ninjastar Engines & Drivetrain 4 09-22-2011 10:05 PM
New Weird Sound in my Wrangler JoeyMS Engines & Drivetrain 1 01-16-2009 05:41 AM
New '08 JK; weird engine ticking sound.. lordblack Engines & Drivetrain 0 07-28-2008 10:35 PM
Weird Sound Coming Out of Speakers Thump85 Audio, CB & Ham Radios, GPS, & Electrical 9 05-03-2006 07:31 PM
