Ford 8.8 Identification?? - JeepForum.com
post #1 of 3 Old 10-03-2012, 08:25 PM Thread Starter
2002TJX65
About to buy a Ford 8.8 for a swap into my TJ. Axle tag says it has 4.10 gears. Just to be sure, I had the owner check the ring gear to see if the ratio was pressed onto it, like it usually is. The only thing he could find was the code in the picture below. It did not say the gear ratio. The axle tag checks out, but anyone could have changed that. Anyone know how to decifer the code in the picture below? I would have expected a 4L10 or 42 code... Please help!
03 Rubicon: Build in Progress
02 TJ: Built and totaled
86 CJ7: Sold
2002TJX65 is offline
post #2 of 3 Old 10-03-2012, 08:26 PM
Showtime3492
count the teeth on the ring and pinion and divide.
--1998 XJ "Mater"- RIP
2000 XJ--- 4.6 stroker. Saved from the grave- everything swapped or modded. I hate this thing :)
Showtime3492 is offline
post #3 of 3 Old 10-03-2012, 08:28 PM
Showtime3492
also D2 is a 4.10 8.8 code just fyi
