Ford 8.8, Dana 44, or Super 35 - Page 2 - JeepForum.com
post #16 of 22 Old 03-19-2006, 10:10 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
Originally Posted by Wheelin98TJ
I was going to install a c-clip eliminator kit in my 8.8, but I had a couple different gear reps advise against it.
They told me installing a c-clip eliminator kit will usually cause oil leaks around the bearing and flange area. And both of these guys are pretty knowledgable. One was a guy from Reider Racing who I've always dealt with. And just to make sure he wasn't giving me a load of crap, I also verified this with someone at Randy's R&P.
So its not from personal experience, but I definitely trust the opinions of the guys who gave me this advice.
definetly worth knowing, I googled for about 4 hours, and only came up with a whole bunch of drag racing applications, and some road coarse guys, few mentioned that the old applications use to leak, but non of the newer applications seemed to be a problem.
I even tried searching for off road applications and only came up with people wanting to sell them.
I hope some one reading this can offer real world usage in the off road / rock crawling arena and confirm that there is still an issue with leakage from flexing to much.
All though with all the searching I did find that most of them said that you would have to first break the 31 spline shaft before the C-clip would even become an issue and most of these guys commenting on them were all running the C-clip elimin's on 10.99 sec or faster cars per NHRA rules.
Back Road Jeepin
BackRoadJPin is offline
post #17 of 22 Old 03-20-2006, 08:21 AM
00Vert
Originally Posted by 92 Green YJ
I do the 8.8 or the dana 44. look to M.O.R.E. for all the brackets and such you will need, they sell kits with all the parts you will need to do the swap
Who is M.O.R.E. ? Couldn't find them on Goggle. Phil
00Vert is offline
post #18 of 22 Old 03-20-2006, 09:58 AM
E_ROCK
http://www.mountainoffroad.com/more.htm
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #19 of 22 Old 03-25-2006, 11:40 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Has anyone broken an 8.8 shaft? If so, what tires/gears/motor were you running and what were you doing to it at the time?
If one did break an 8.8 shaft, other than having to remove the diff cover to remove the c-clip & shaft chunks, how would the c-clip cause a problem or is it just that it would allow the rest of the shaft (and tire) to slip out?
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #20 of 22 Old 03-25-2006, 12:47 PM
mctonyb
I'm sure it has happenend, but I don't know anybody that has broken an 8.8 shaft.
I was in the same boat as you were.. I did the 8.8 myself and it was dirt cheap and is a super strong axle.
TJ on tonnes at 110" WB with 40's and no money in my pocket
mctonyb is offline
post #21 of 22 Old 03-25-2006, 08:30 PM
GSXMEN
If you upgrade to a disc brake 8.8, it would be much less likely for the axle to be able to walk out of the housing. Kind of similar to the secondary hood latch.
Don't forget......the 8.8 with 31 spline has an axle that is the same size as a Dana 60. That's pretty beefy!! If you need extra insurance, get some Moser axles(or other) and call it good!!
Spend the extra $160 on a TA Performance rear end girdle. That will help ensure that the guts stay put. Just my opinion, of course.
Scott
*PM or email if you need an 8.8 with 4.10 gears - open or Trac-Loc*
GSXMEN is offline
post #22 of 22 Old 03-25-2006, 09:43 PM
92 Green YJ
92 Green YJ's Avatar
it shoube stated that if you do break a shaft, the disc brakes will only hold well enough to limp off the trail on. DO NOT try and drive on the road at speed with just the calipers to hold the broken shaft in!!!
however, i have never seen anyone break, nor do i know one who has broken an 8.8 shaft. I wheel my YJ hard and my 8.8 lives just fine and dandy with an ARB and 35s on steel beadlocks
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
Dana 60 Vs Ford 8.8 DARRTILLM Engines & Drivetrain 2 10-08-2008 01:53 PM
Dana 44 or Ford 8.8 Apex Engines & Drivetrain 6 09-10-2008 08:14 PM
Super dana 35 Vs. Ford 8.8" gabrod72 Engines & Drivetrain 9 04-18-2008 11:48 PM
Ford Dana 44 vs Jeep Dana 44.. ((~JEEP~)) General Jeep & Off-Road Equipment 7 07-15-2007 03:34 PM
What can you tell me about the Ford 10.5 / Dana 50 / and Ford Excursion? SPL Tech Engines & Drivetrain 15 01-10-2007 07:01 AM
