Ford 289 in CJ 2A, what to do to it? - JeepForum.com
post #1 of 4 Old 01-24-2002, 05:12 PM Thread Starter
2001gtboy
It not running yet but while were on that track might as well upgrade anything instead of by stock replacements parts. Any idea on making more power and torque?
My 2001 Mustang GT daily driver
2001gtboy is offline
post #2 of 4 Old 02-22-2002, 04:34 PM
ebhub
Go with a good header, intake and carb. If it is an old 289 than swap in a points conversion kit.This should give decent power.If you want more go with a small supercharger.
ebhub is offline
post #3 of 4 Old 02-24-2002, 01:23 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
A stock 289 has more power than you could probably use in that chassis, and will start and run in hot weather and cold.Beware, the T90 3 speed trans and model 25 front axle are marginal under hi power engines.Just some thoughts, good luck on your conversion
bazinga
jeepdaddy2000 is offline
post #4 of 4 Old 02-24-2002, 04:32 PM Thread Starter
2001gtboy
i just need money to continue )
ford ECU ???? LDStoddard Audio, CB & Ham Radios, GPS, & Electrical 7 07-08-2009 03:58 PM
What can you tell me about the Ford 10.5 / Dana 50 / and Ford Excursion? SPL Tech Engines & Drivetrain 15 01-10-2007 07:01 AM
Ford 10.25?? ?? Bduke911 Engines & Drivetrain 8 11-12-2006 04:41 PM
Ford 5.0 in a TJ southdakotatj Engines & Drivetrain 1 11-15-2004 02:27 PM
my new ford 8.8 hockeynhoots10 General Jeep & Off-Road Equipment 9 10-14-2004 05:30 PM
