Flywheel/Driveplate/Flexplate and Crank Position Sensor - JeepForum.com
post #1 of 3 Old 11-28-2002, 11:25 PM Thread Starter
jeeprad
On 4.0L with the Crank Position Sensor how do you ensure that the Flywheel/Driveplate/Flexplate is bolted to the crank in the proper orientation?? Will the six bolts only line up one way??
I've not seen where the FSM addresses this issue making me think that it will only bolt up one way.
Anyone have experience on this?
1995 Cherokee
Old Man Emu Suspension
231D HD transfer Case
JB Conversions SlipYoke kit
All work completed by owner!
jeeprad is offline
post #2 of 3 Old 11-29-2002, 11:17 AM
CSP
There is only one way that the bolt holes line up on the end of the crank. You can't put it on wrong.
CSP is offline
post #3 of 3 Old 11-29-2002, 11:01 PM Thread Starter
jeeprad
Thank You
Thats what I was hoping, but never really double checked it.
Thank You very much!!
1995 Cherokee
jeeprad is offline
Where is the throttle position sensor??? TJ-Jeep-mate Engines & Drivetrain 2 12-18-2009 01:06 AM
trouble after engine swap 3.7L. different crank position ring on crank nubby Engines & Drivetrain 1 06-13-2009 06:48 PM
EGR position sensor? delta490 Engines & Drivetrain 0 05-14-2008 12:09 PM
Crankshaft Position Sensor????? thjofe Audio, CB & Ham Radios, GPS, & Electrical 2 09-27-2006 12:27 AM
Cam Position Sensor AZG23 Engines & Drivetrain 0 03-02-2006 11:46 AM
