Fluid leaking from dana 35-c - JeepForum.com
post #1 of 2 Old 08-15-2010, 10:27 PM Thread Starter
vfasburg
Hey, I have a 97 TJ with a Dana 35-c in the rear. I've noticed after long highway trips there's differential fluid right on the passenger side of the pig. It seemed to be more of an explosion than a leak, because there was fluid all over the surrounding parts. I assumed it had blown through the pig and onto the axle shaft, which is weird because on the Dana 35-c there is no real seal there. I found the overflow tube valve was clogged, so I replaced the valve, but that didn't change it. Now it happened again and I went nuts with a camera taking pictures of all the places I couldn't look at. One of the pictures showed two holes in the top of the axle shaft, near the pig on the passenger side. I have no idea what these are for, or how to make it stop leaking, any advice?
vfasburg is offline
post #2 of 2 Old 08-16-2010, 02:29 PM Thread Starter
vfasburg
well I figured out why there are holes there, and it makes me feel like an idiot. I replaced the brake lines a while ago and used aftermarket which didn't have the seemingly useless bracket that the stock ones had. I don't know why they decided that those bolts should go right into the axle itself, but mystery solved I guess. Does anyone know what size these are? I don't want to have to go to Lowes and buy one of each billion different sizes to find the right one. Thanks
vfasburg is offline
axle , axle shaft , dana 35 , differential , leak
burning up/leaking tranny fluid mcdcrook Engines & Drivetrain 0 02-08-2010 11:41 AM
3 spd leaking fluid...please help jrandalls Engines & Drivetrain 1 10-29-2008 10:13 PM
Leaking ARB Locker and Bronze Diff Fluid sevise Engines & Drivetrain 2 06-03-2007 12:43 PM
radiator fluid leaking from engine block jeepYJ.TO Engines & Drivetrain 6 03-23-2006 08:35 AM
shock leaking fluid Flatbroke Tires & Wheels 6 10-21-2005 02:43 PM
