Fel-Pro Gasket Set for 4.0L I6 - JeepForum.com
post #1 of 2 Old 06-02-2004, 07:03 PM Thread Starter
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
Does anyone know what the "extra" gaskets are for? I have 2 gaskets that go to the timing cover; one is black and the other is blue w/stripes. Do I use them both or just one of them? The gasket set didn't come with application instructions and my Haynes manual does not indicate that I should have more than one gasket.
Insight please.
Thanks!
- Brian
Brian's 97 ZJ is offline
post #2 of 2 Old 06-03-2004, 07:40 AM
75SV1
Insight please.
Thanks!
- Brian
Brian,
Just use one that matches your front timing cover. I usaully end up with extra gaskets from gasket sets from various cars. The manufacture may cover different years or simular engines this way. It keeps down on the need to stock many different gasket sets. Packaging many times cost more than the item. Usually 1/4 the cost of the product is in packaging and transportation. So if they can cover a few more applications by adding in a gasket or two, it saves money in the long run.
Tom
75SV1 is offline
Fel-Pro Gasket Kit th3t1nm4n Engines & Drivetrain 2 12-14-2009 08:41 AM
4.0L head gasket? BlackedOut98 Engines & Drivetrain 2 01-13-2009 03:12 PM
Do I need gasket sealer on a new oil pan gasket? jeepster93 Engines & Drivetrain 4 10-19-2008 12:18 AM
258 Head Gasket Job BUDGETBEAST Engines & Drivetrain 6 07-30-2007 06:03 AM
Head Gasket Plink Engines & Drivetrain 1 01-08-2005 11:22 AM
