failed the roller test - JeepForum.com
post #1 of 2 Old 05-04-2012, 02:21 PM Thread Starter
ITSKOOL
i just got my 2000 wrangler sport last week. it has the optional d-44 rearend option, but i wasnt sure if it had the limited slip option also. we took it out to the old hummer dealer test track, which much to my surprise had an area where you could put the 2 front tires and the right rear tire on rollers. i engaged the 4 wheel drive and let out the clutch. 3 tires spinning the rollers and 1 tire doing notta. this is pretty much gonna be a street jeep with maybe some light 4 wheeling, but i really want to upgrade the diff to a limited slip or locker at some point. now i see why the instrument panel says PART TIME instead of 4 WD when you engage the transfer case, lol.
ITSKOOL is offline
post #2 of 2 Old 05-04-2012, 07:11 PM
jnicewan
I dont get your comment but ok, a full time 4wd would react the same way. A 2wd with a limited slip or locker would have pulled off the rollers so 4wd actually would not have been needed. I would say if you are mainly street driving you should look at the limited slips like tru-trac or something. Or if you want the best of both worlds look at selectable lockers. Some of the selectable lockers are limited slips when unlocked and some are open diff when unlocked.
jnicewan is offline
Hawse or roller?? 77351wcj5 General Jeep & Off-Road Equipment 12 11-30-2011 11:37 AM
Roller Rockers djsrtr Engines & Drivetrain 1 07-30-2011 09:11 AM
Warn 9.5TI has failed many times are there others that have failed? johnny1720 General Jeep & Off-Road Equipment 84 01-27-2010 10:51 AM
Roller Cam? fedrusion Engines & Drivetrain 1 01-17-2008 09:48 AM
Roller Rockers? jaykump Engines & Drivetrain 7 12-05-2007 10:27 AM
