Exhaust sounds deeper and check engine light comes on? - JeepForum.com
post #1 of 12 Old 10-08-2012, 04:58 PM Thread Starter
Tmblack3
I went wheeling this weekend and bumped some rocks on the undercarriage, no noticeable damage but my exhaust has a lower rumble sound and now 2 days later my check engine light just came on, any ideas?
04 TJ Sport- Kicker System, Smittybilt XRC-8 Winch, Cherry Bomb 18" Glasspack, 3" Zone Hydro Suspension Lift, 33x12.50 BFG KM2, 15x8 Procomp 7069, Aussie Locker front Dana 30, JKS 1.25" Body Lift, 4 100w Hella 500s
Tmblack3 is offline
post #2 of 12 Old 10-08-2012, 07:43 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
You probably popped open a crack in your exhaust system and one of the O2 sensors has picked up free oxygen in the exhaust stream.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 12 Old 10-08-2012, 07:57 PM Thread Starter
Tmblack3
Are there any certain points that i should look at?
Tmblack3 is offline
post #4 of 12 Old 10-08-2012, 08:07 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Start where the down pipe(s) connect to the exhaust manifold.
Look for where the exhaust is making that rumble sound you mentioned...
post #5 of 12 Old 10-08-2012, 08:17 PM Thread Starter
Tmblack3
Ok, theres no puffing sound coming from the front like i hear from other peoples leaks, it just sounds deeper like maybe something cracked in the catalytic converter.
Tmblack3 is offline
post #6 of 12 Old 10-08-2012, 08:26 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Now you need to scan the trouble codes and see what they indicate.
post #7 of 12 Old 10-08-2012, 09:17 PM Thread Starter
Tmblack3
Ya im gona do that at advance auto tomorrow
Tmblack3 is offline
post #8 of 12 Old 10-09-2012, 04:53 AM
pshivers
2008 KK Liberty
If you have an android phone, the $5 Torque app and a cheap $15 ELM327 Bluetooth OBDII device is the best investment I ever made. It's like having a nice $200+ scan tool for nothing. Comes in very handy. Not only can you look up and clear codes, but you can look at live data from the computer. You'll be able to see if the O2 sensors are stuck lean because of extra oxygen in the exhaust and not just guess based on the codes.
pshivers is offline
post #9 of 12 Old 10-09-2012, 06:43 AM Thread Starter
Tmblack3
Nope, i have an iphone. Ill be going to advance auto in an hour or so to get the code scanned.
Also, something rattles in the undercarriage and it sounds like its something with the exhaust, like something bumping against the tube. It only happens when i start the car, then after 10-15 seconds it stops and i cant get it to do it. It only does it at the idle speed, about 1000-1100 when the car is just started. If i give it some gas, in neutral, it goes away and once the rpms fall back down it will go back to doing it.
Tmblack3 is offline
post #10 of 12 Old 10-09-2012, 07:49 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
That could be a loose heat shield on the muffler. My question to you is, Was that noise there before your little 'full contact' off road adventure?
post #11 of 12 Old 10-09-2012, 08:06 AM Thread Starter
Tmblack3
No it didnt make the noise before
Tmblack3 is offline
post #12 of 12 Old 10-09-2012, 08:17 AM
asim04LJ
Do the key trick to retreive any codes. Off to On 3 times quickly, leaving it on "ON" and it will display the code where the odometer reads.
http://www.jeepforum.com/forum/f9/fa...-codes-778086/
asim04LJ is offline
