Exhaust Manifold opionions - JeepForum.com
post #1 of 3 Old 11-30-2012, 10:32 AM Thread Starter
DTater
Exhaust Manifold opinions
I need to replace my manifold. It has a crack between #2 and #3.
I've got the 2.5L in my '97 TJ
I have found Dorman and OMIX-ADA sell one.
The price is relatively close between the two.
The Dorman has a heat shield and a plugged hole near the tailpipe junction.
The OMIX-ADA has neither.
Does anyone have an opinion on which manifold is better? Better fit? Better quality?
I do thing the Dorman comes with a lifetime warranty, not sure I will keep the jeep that long.
Also, I would think I should replace the studs and bolts during this task.
I assume I can use the standard bolts found at a hardware store.
Where would i find the studs?
DTater is offline
post #2 of 3 Old 12-01-2012, 05:52 AM
76flh
i had both of them and they both cracked. i even replaced them while they were under warranty and that one cracked to. i then but the banks header on and have had no trouble with it.
76flh is offline
post #3 of 3 Old 12-01-2012, 09:40 AM Thread Starter
DTater
Thanks, the banks is just so expensive.
I may look for an OEM one in a salvage yard
DTater is offline
