Everyone please vote _________. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Everyone please vote _________.
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 06-11-2002, 10:02 AM   #1
jaybyrd
High mileage I6 4.0L (230,000 Km), what engine oil is better for reducing oil consumption and still allow for good engine performance.
15W-40 or 20W-50
[COLOR=DarkSlateGray][FONT=Arial Black]1993 XJ Sport 4DR STOCK
4.0L I6 H.O. AX15
NP231 DANA 30 FRONT
CHRYSLER 8.25 REAR [/FONT][/COLOR]
jaybyrd is offline   Reply With Quote
Unread 06-11-2002, 10:52 AM   #2
Dan's YJ
I would use 20W-50.
1994 Bronco HD
Warn 8000
2"lift, 32x12.50
Locked
Dan's YJ is offline   Reply With Quote
Unread 06-11-2002, 12:33 PM   #3
Eryl Flynn
Holy crap, do the 4.0s last that long normally? I have 130k on mine, and was planning on a swap in 2 years maybe.
Eryl Flynn is offline   Reply With Quote
Unread 06-11-2002, 12:49 PM   #4
jaybyrd
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by Eryl Flynn:
<strong>Holy crap, do the 4.0s last that long normally? I have 130k on mine, and was planning on a swap in 2 years maybe.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Mine is still running strong, but consuming a fair amount of oil, likely valve seals which is why I'm looking for advice on a higher viscosity oil.
4.0L I6 H.O. AX15
NP231 DANA 30 FRONT
Unread 06-11-2002, 12:57 PM   #5
4wheeler4CJ
I run 20W-50 in ALL/ANY engine that has 100,000 miles or more, and it helps them last without repair for well over 200,000 miles, and much more. If you search the threads, you will find many topics on this, and my position on 20-50 is further explained. <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline   Reply With Quote
Unread 06-11-2002, 03:01 PM   #6
Parajeeper
I second using 20W50
Parajeeper is offline   Reply With Quote
Unread 06-11-2002, 08:25 PM   #7
pop_r_master
yeah 20w-50..and right after you put in the oil, pull the motor and put in a dodge v-10 yayayay...yeah thats the ticket!!!!
99 TJ 4.0 Bone stock.....You play CS? come to my server sometime, Id love to shoot you.
pop_r_master is offline   Reply With Quote
Unread 06-12-2002, 03:29 AM   #8
cj7traildriver
AHH why dont yah just replace the cheap valve seals, pull the valve cover, if you can't charge the cylinder with air to keep the valves up pull the spark plug which need to do anyway get rope that fits thru the hole long enough to put a fair amount in turn engine over till rope is pushing up on valves, compress valve springs pull off seals and replace put back together repeat thru all cylinders.
Jeep what else matters.
cj7traildriver is offline   Reply With Quote
Unread 06-12-2002, 06:08 AM   #9
jaybyrd
Switched over to 20W-50 yesterday and the jeep has never run better. Time will tell if it consumes less oil. But the horsepower and top end is up substantially.
4.0L I6 H.O. AX15
NP231 DANA 30 FRONT
Unread 06-12-2002, 08:23 AM   #10
Dan's YJ
Good, keep us posted.
1994 Bronco HD
Warn 8000
2"lift, 32x12.50
Locked
Unread 06-12-2002, 10:57 AM   #11
4wheeler4CJ
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by jaybyrd:
<strong>Switched over to 20W-50 yesterday and the jeep has never run better. Time will tell if it consumes less oil. But the horsepower and top end is up substantially.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Works every time! <img border="0" title="" alt="[Wink]" src="wink.gif" /> Precisely why I use it after 100,000 miles. I basically throw out the service manual specs after 100,000, since they do not apply to most things at that point, LOL. 5W-30 and 0W-30 oil is like putting tap water in your motor, and 10W-40 just doesn't cut it at 100,000.
Every vehicle I have had has run much better from a switch to 20W-50 at 100,000 or close to 100k: more HP, less oil consumption, better mileage, higher oil pressure, cleaner oil at oil changes (hence running better).
Good Luck!
Unread 06-12-2002, 11:04 AM   #12
Eryl Flynn
What about synthetic? I been running synthetic and I don't remember seeing 20/50 as an option at the stores I shop. Should I look around for a 20/50 synthetic on mine then?
NOTE: I like the synthetic, so far in 3 years had almost nothing wrong with it.
Unread 06-12-2002, 12:03 PM   #13
jaybyrd
As I found out 20W-50 is used most frequently in motorcycle engines. In canada you can pick it up at any Canadian Tire store. Not sure about the U.S. but try around its not that exotic, and the kind I put in is a synthetic, not sure if it comes plain old petroleum based that heavy.
good luck
4.0L I6 H.O. AX15
NP231 DANA 30 FRONT
Unread 06-13-2002, 08:22 AM   #14
4wheeler4CJ
For some reason, I seem to remember seeing synthetic in 20-50, but not sure. It is widely available in standard oil. I'm not an advocate of synthetic, not that it is crap, just that I don't justify the difference in price. Duration between changes is NO different, since the same "dirt" accumulates in your oil anyway and needs to be changed out. Anyway, without going into that discussion , you may be able to find synthetic in 20W-50. <img border="0" title="" alt="[Wink]" src="wink.gif" />
Unread 06-17-2002, 06:40 AM   #15
woodmanswaggy
my jeep has 191,000 on it. the oil pressure was really low. and someone said put in 20w50 and boy did it make a difference.. im gonn keep using that from now on it my waggy.
woodmanswaggy is offline   Reply With Quote
