Evap and crankshaft position sensor? - JeepForum.com
post #1 of 6 Old 02-04-2012, 08:12 AM Thread Starter
BulldogTJ04
Hey guys just a question here kinda weird. I'm losing top end power and sounds like my engine is starving when I get up around 60mph. Any ideas would be helpful thanks a lot in advance
BulldogTJ04 is offline
post #2 of 6 Old 02-04-2012, 08:13 AM Thread Starter
BulldogTJ04
Oh sorry 2004 TJ 4.0
post #3 of 6 Old 02-04-2012, 02:21 PM
jnicewan
I would probably start with checking the simple things. Check for codes, check air filter, spark plugs etc. Maybe do a fuel pressure test. Loss of power under load at higher RPM can be any number of things, but stopped up air filter, restricted fuel filter or weak fuel pump are most common, maybe even worn spark plugs. On top of that a restricted exhaust or catalytic convertor could be the problem too.
jnicewan is offline
post #4 of 6 Old 02-09-2012, 01:58 PM Thread Starter
BulldogTJ04
Ok so I changed all the plugs (they didn't look bad). Did an oil change, air filter. Checked the codes and am getting a misfire 4,5,6 cylinders. Says possible crankshaft position sensor or camshaft position sensor. So I bought the crankshaft position sensor to try out first since its the cheaper of the two. Where is this thing located???
post #5 of 6 Old 07-06-2012, 07:19 PM
thegreenbastard
On top of the transmission bell housing the easiest way to get to it is to (as bad as it sounds) cut a hole in the floor right next to your 4x4 shifter. It's a tough little guy to get at
thegreenbastard is offline
post #6 of 6 Old 07-07-2012, 01:06 AM
jnicewan
Keep in mind, (and I am only pretty sure about this for your application) Cylinders 4,5,6 all share one catalytic convertor, 1,2,3 share another. If a convertor is clogged and depending on which one, it will affect 4,5,6 or 1,2,3. A clogged convertor also usually causes a loss of power under load at higher rpm.
jnicewan is offline
